Question about Philips Magnavox 51MP392H Rear Projection Television
Our television is about 11 or 12 years old. It
Our television is about 11 or 12 years old. It began making a popping sound about every 2 or 3 minutes... then it began to increase until it was constant and the screen went black. still have sound. Is this the Tube, and if so... is it very expensive to fix
  • 438 Answers
Your problem is more likely to be in the high voltage fly-back transformer or HV tripler supplying high voltages to the anodes to your picture tubes these voltages range from about 20 to 40 thousand volts, replacing these components are relatively reasonable in price and depending on where you live will cost no more than about 300 dollars
Posted on Apr 27, 2010
My RCA tv has been working fine for years. A few days ago it began to have intermittent popping sounds. Picture is clear and sound is good. I recently dusted the back of my set and I'm sure some dust must...
hi there,
if u know how to work with your set u can:
1. open the back cover case of your tv and try to find a foreign objects inside and clean it up with your vacuum cleaner.
2. popping sounds sometimes due to lossen parts, bad socket contacts, too much dust and dirts ,corrosions .and when cleaning you unplug first your TV set to avoid electric shock. i hope this will help a little. Thank You.
Feb 08, 2011 | RCA TruFlat 27F520T 27" TV
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
TV screen went blank and it began clicking, turning itself on/off repeatedly. Had to unplug from wall to make it stop. TV is only 2 years old and has worked perfectly until now.
the power supply board has failed. call 1-800-samsung for nearest service center. power supplies are usually $125.00 plus labor, 1 hour maximum to repair.
Nov 24, 2009 | Samsung LN-T4665F 46 in. LCD Television
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
Popping sound with picture
try getting a cleaning kit from radio shack for 15 bux the lens maybe dirty
Jan 21, 2009 | Haier TN201AUV 20" TV
Hitachi 50V720 Rear Projection TV
Good Day, douganddawnc;
What ever is popping is locking up the CPU circuit. Call a Factory Authorized Service Center Have figure out what is popping, get an estimate first. Good Luck, big IRISH.
Aug 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
