Question about HP Compaq Presario V2000 Notebook
There is sme problem wh ma laptop wen i am
There is sme problem wh ma laptop wen i am plugging it wh d power n starts ma laptop .all d buttons r working n showing lite as wel bt d screen is nt workng ..wat i do nw.
    Guru:
  • HP Master
  • 1,705 Answers
If the screen shows a picture but very faintly, the inverter is either not connected properly or faulty.
If there's nothing on the screen at all
1) Your screen is either not connected properly or faulty.
or 2) *********** board has a fault.
or 3) Your graphics card/chip has a fault.
You can connect your laptop to another screen using the VGA port on the back. You have to switch to the spare screen using the keyboard, usually Fn and another key. If the spare screen then shows a picture, *********** board and graphics card are OK, your screen is at fault or not connected properly.
Checking the connections to both the inverter and screen will require dismantling you laptop. If you go about this, ensure all power, including the battery is disconnected.
Posted on Apr 26, 2010
Hi I have an Ignis built in oven model number- AKL907/WH which is now displaying "- - - c" and t won't let me press any buttons to correct it, the oven itself does not turn on, any suggestions please? No...
Sounds like a bad electronic control board. Proper replacement might require a service tech. TRY resetting by unplugging it from the wall. Give it a few minutes, then re-plug. Also look for any sort of reset, switch, lever or button.
Dec 15, 2013 | Ovens
Require schematicwiring ofma400 and high power 2 lutron dimmer
You can access Lutron's Wiring Library here:
http://www.lutron.com/Service-Support/Technical/Pages/WiringDiagrams.aspx
I couldn't find an MA-400 or High Power 2 dimmer, so you might want to double check the model numbers and look for a match in the link above.
Jan 02, 2012 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I am trying to install two Lutron dimmers in the same box. The dimmers are models MA-S8AM-WH and MA-600WH. I can get get the MA-600-WH to work but not the MA-S8AM-WH. Anyone have any hints.
My first thought is that if you were using these devices to replace existing light switches, the MA-S8AM has an additional electrical connection that wasn't necessary with a light switch or the MA-600. The MA-S8AM has an addtional screw on it (I think its silver in color) that connects to the neutral wire in the circuit. Hopefully you have a bunch of white wires all wire-nutted together in the back of the box - pull a connection from there and attach.
If that's not the issue, then I would call Lutron's tech support. They're available 24/7, so you may as well. They're at 1-800-523-9466.
Aug 25, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
I have a renault clio 1.4 R reg it misfires
misfire could happen if you have a leak in the intake or exhause valve , or if your engine running rich thats mean too much fuel coming to the engine . you should check oxygen sensor
May 31, 2009 | 2005 Renault 181
Clio 1.8 16v L reg misfire
oxygen sensor is your problem.
May 19, 2009 | 2005 Renault 181
No click.
it is in a stanby, wen power it runs to 2-3 seconds then it back to sanby
Jan 19, 2008 | Sanyo DS24425 24" TV
HP Compaq Presario V2000 Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
