Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
The water and ice dispenser not working now it wont keep cold
  • silburns May 11, 2010
    elaborate please
  • GE Master
  • 4,655 Answers
The problem is most likely related to the wiring at the pin plug at bottom of door hinge. Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION SWeems i have solved 3 like this this week. Most times corrosion gets into the plug and stops the dispenser from working. When you get to the above link/page the first photo top left and the wiring diagram below and top left corner, J4 Plug leads to dispenser and temperature controller. Click on wiring diagram to download a Service Manual. Grt with me as soon as you can so I may help you resolve this. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Apr 27, 2010
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
My water dispenser and water to ice maker isn't working. any suggestions?
my monogram ice maker wont make ice. it is on, the water fills the pan but thats as far as it gets. the area is cold. the hoses appear open. i have cleaned the dust of the compresser. what else can i do before i call the repair man?
Jun 15, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker makes ice, but not nearly as much as it used to. What do you suggest. Water flow out dispenser is fine. Filter has been replaced.
I would suggest making sure the coils under the refrig are clean of dust , lint , pet hair , etc . Also , letting the ice build up so it gets closer to the bottom of the ice maker (coldness of the ice will help keep the ice maker cold ) will result in ice maker cycling more often (making ice) .
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will make the switch to start the cycle.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 19, 2009 | Refrigerators
The water/ice dispenser will not dispense neither ice nor water..
There is a door switch that senses the door being closed for the dispenser to work. The water problem could be a plugged filter if you have one. Was the frig extremely cold recently? The water resevoir can freeze up. (its located behind the crispers) It could be the switches in the dispenser itself. Process of elimination will lead to the problem.
Eric
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser wont work....ice maker works
Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
Mar 14, 2009 | Refrigerators
Ice maker
new icemaker,wont fill up with water when it calls
Jan 24, 2009 | Frigidaire FRS26R4A Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
there is an electric valve that controls the water to both the ice and water. I had to replace the valve for the same problem.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
