Question about Formac Gallery 1900 Oxygen 19" LCD Monitor
How do I take apart a Formac Gallery 1900 monitor?
3 Suggested Answers
SOURCE: backenlight inverter panel failure formac gallery 1900 oxyg
mine had the same problem, replaced the fuse with a T2.5 amp.
Ammeter gave a reading of 1.6A across the fuse pads so we shall see if its pops...
Posted on Oct 18, 2008
SOURCE: i need a new power supply for a formac 1900
I've got two and you are welcome to one if you pay pp plus a sensible offerI live in South London UK
Posted on Oct 13, 2011
I need a new power supply for a formac 1900 monitor
May 19, 2011 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Suddenly, after no previous problems, when computer (Mac- G5, older, not intel) started up in the morning, the monitor, although power light on, displays only black screen. Monitor is lcd Formac- not...
Try hooking it up to another PC first, but more likely to have failure in the power supply caps or failed inverter cicuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
The monitor has power, but there is no picture. can this be repaired?
May 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
My formac dvi monitor wont work as a 2nd monitor for my laptop
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
May 07, 2010 | Formac Gallery 2010 20.1" LCD Monitor
Hi it is running darker than it should and the power supply is getting very hot, I have changed the power supply, the problem persists
there must be an overload at o/p of smps check the silicon device such as diodes or transistor or any chip on the board
Apr 18, 2010 | Formac Gallery 2010 20.1" LCD Monitor
Power button lights up but screen stays blank
First you check the problem with monitor or cpu.you can check it by other monitor.after replacing the monitor it gives not display. then your monitor has any hardware issue.then you can repaired it from service center.
Mar 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Backenlight inverter panel failure formac gallery 1900 oxyg
Aug 01, 2008 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Formac Gallery Monitor
Looks like the water is getting in to the LCD contacts. Or corroding them. If the monitor can be opened safely open it and place in a warm dry environment for a few days. Silica dehumidifiers may help.
If the issue is not permanent this may fix it.
Jan 27, 2007 | Formac Gallery 1740 Oxygen 17.4" LCD...
Formac Gallery 1900 Oxygen 19" LCD Monitor Logo
59 people viewed this question
Top Formac Computers & Internet Experts
David Payne
David Payne
Are you a Formac Computer and Internet Expert? Answer questions, earn points and help others
