Question about Sony NW-A1000 MP3 Player
Water damage my NW-A1000 6GB was drowned in a pool of vodka i turned it on while it was still wet and now only the link button illuminates i need to know how to open the system so i can remove rust and calcium that might be f@&%ing it up
  • 40 Answers
There is no calcium in vodka, nor are any of the compents pron to rust.
parts of the board may corrode, but more then likely turning it on when wet shorted/fried a chip
you cant' fix it :( better off just buying a new one.
Posted on Mar 24, 2008
How to get ride of snails in garden
my parents use to put out trays with beer in them worked every time
Sep 16, 2015 | Cars & Trucks
I have an 2007 arctic cat 500 i drowned it and it turned off , i cleaned the carburator , i changed the spark plugs . it has spark and the gas gets to it but it still wont turn on . what could the pro
You DROWNED it? Meaning you ran it into water so deep that it killed the motor? Chances are very good that you've done some very serious damage to that engine. Water doesn't compress, so you may have destroyed a piston or cracked the head.
Additionally, water - particularly if that water wasn't exceptionally clean (like distilled water) - will have done anything electronic no good at all, and chances are excellent that it's gotten into every gearbox on the machine.
Last and least, it may have gotten into your fuel tank. At least THAT's easy to drain & refill & add Heet to.
Aug 04, 2014 | Arctic Cat 2007 500 4x4
Got wet and it works but no back light - the screen is really dark
Simply its wet and damaged and your lucky its working. You can try leaving it over night in a bowl of rice just drowned in the rice. Dont add water or anything else just rice. The rice works as an absorbant and it may remove that extra water that hasnt been able to try because it is inside the ipod.
May 02, 2011 | Apple iPod touch
How do you use the rainbow to **** up a large amount of water from an air conditioner tray
You simply begin with an empty water basin, turn the unit on, and gingerly slurp the water away. Do not plunge the nozzle into a pool of water. Afterall, this is a vacuum cleaner, it moves air and the water/debris you kick-up into the air, not a water pump. The standard basin has a maximum capacity of 2 quarts, before the unit effectively drowns. If you have the special larger basin, then it has a 4 quart capacity. If you are trying to remove a larger volume of water, then you will have to empty the water basin multiple times. Unfortunately, you have to keep a close eye on the water level, so that you do not drown the vacuum.
Mar 23, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Will the saltwater harm the grass if I drain the pool?
Most salt systems need 3-4000 ppm of salt in the water to operate. (which is no big deal).You will probably do more damage" Drowning" your lawn.There is a lot more water in there than you might think.
Sep 27, 2010 | Intex Automatic Salt Water System for ...
Spilled vodka on my phone (LG Shine). Diddnt get too wet. The little whit sticker is still white so apparently it did not get to wet. Now the phone will turn on, show the AT&T logo, and then turn off....
The next solution is about water damage , just try it for your problem :
This works on most mini electronic devices like cellular phones and degital cameras etc . it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY .
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
rate if useful please !
Jan 21, 2010 | LG Shine KE970 Cellular Phone
Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Feb 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Water Damage
Bad news! Sorry but electronics and water (vodka n coke) don't mix well, even just a little. Even if you removed the battery immediately, and let it dry over night, it probably still wouldn't work again. Even if it does come on the coke would make the keys and switches lock up. Sorry.
Dec 29, 2008 | Casio Exilim EX-S880 Digital Camera
Water Damage?
today i went on my slip n slide with it in my pocket annd it got all wet. but then to make it worse i dove into my pool not even knowing it was in my pocket. but it works completely now=)))
Jun 12, 2008 | Pantech Duo Smartphone
Sony NW-A1000 MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
