Question about Kyocera Mita FS-3830N Laser Printer
Removed developer unit from a kyocera fs-3830dn. when replaced, no image printed on paper. seemed to work normally, but no toner image on paper appears, just blank pages.
  • 622 Answers
You have a bad developer unit
Posted on Apr 26, 2010
  • rods388 Dec 08, 2010
    i've already change the developer unit.
  • my84bmw Feb 22, 2011
    If you've never changed a dev unit, then you may not know that there is a flap that needs to be lifted to expose the full-width mag roller - you have to raise the flap prior to inserting the dev unit into the printer - then it will insert easily and fit properly. Also you may (depending on whether the dev unit is empty) need to access the Service options in the menu, select Developer, hit select, get the ? indicator, hit select again, that window will go away, then you need to cycle power on the printer - this will start the developer "adding toner" process which can take up to 15 minutes - let it run, and when it is complete, you should have a functioning 3830.
  • 60 Answers
On an fs 3830 when you put in a new developer unit it need to be deved up. You need to go in to the menu go to other in other goto service/maintainence. In the you see a mode it will say developer. Hit the ok button twice the machine is now in dev mode. .niw turn the machine of and back on the the Toner will start filling up the dev unit make sure you toner is at least half full as it fill the dev unit up with toner. After you turn on it will usually come up with the message adding toner this will last for abot 15-20 minutes while it replenishes the new developer unit .hope this helps
Posted on Apr 02, 2015
    Master:
  • Kyocera Mita Master
  • 552 Answers
Write your answer...Dear pl. check the high voltage contacts to the developer roller blade etc to the base contacts.
thanks.
Posted on Mar 20, 2015
After replacing developer unit, you have to run u130. The developer isn't shipped with toner in it.
Where is developer unit in kyocera fs 1370dn
the developer unit for this printer looks like this.
26367533-y50xtmg3b3sor10el1acrrt1-1-0.jpg The unit can be found under the toner cartridge.
Here is a link on how to remove the toner cartridge.
okm2000 de Kyocera FS 1370DN 1370 1350 1320 Tonerwechsel Kopierer Drucker...
Best regards,
Marius
Nov 22, 2016 | Kyocera FS-1370DN
How do I install a new genuine kyocera developer unit (dv-172) in a Kyocera Y FS-1320D?
1-5-4 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the front cover.
3. Remove the developing unit (with toner container).
4. Check or replace the developing unit and
refit all the removed parts.
5. When the developing unit is replaced with a
new one, carry out the following procedure.
6. Perform toner install mode in the service
mode (see page 1-3-12).
May 26, 2014 | Kyocera Office Equipment & Supplies
Dark lines fs 3900
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
Apr 15, 2014 | Kyocera FS-3900DN Laser Printer
Background printing
This can be caused by not using genuine toner. Drum,developer or fuser unit may require replacing.
Mar 17, 2013 | Kyocera Mita FS-1920 Laser Printer
My kyocera fs-1370dn suddenly says it is missing a developer unit when the developer unit is there and was just working
Check that the toner you are using is genuine Kyocera, also that the toner hasn't run out, this is normally a toner related issue.
Dec 21, 2012 | Kyocera FS-1370DN
Error code 7410:0167274 on a Kyocera FS2000D, what does this mean?
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
The drum unit is not installed or not installed properly.
Detaching and refitting the developer unit Procedure
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
Detaching and refitting the drum unit
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Jun 10, 2011 | Kyocera FS-2000D Laser Printer
Kyocera FS3900DN changed toner and got error 7410:0163053 to call for service
Shawn
Feb 25, 2011 | Kyocera FS-3900DN Laser Printer
I have a Kyocera fs 1920 printer how do I replace the drum with a new one
1. Remove the paper cassette and the paper transfer unit. (Draw the paper transfer unit while pressing the buttons in)
2. Remove the developer unit.
CAUTIONS When if installing or removing the developer, do not let the magnet roller touch any part in the printer.
A. Open the top cover.
C. Remove the toner container.
D. Disconnect the developer connector.
E. Remove the developer from the printer while sliding the developer lock lever frontwards.
F. Gently flip down the magnet roller protective cover.
NOTE After removing the developer, seal it in the protective bag and place it on a flat surface. Do not place the developer in a dusty area.
3. Remove the waste toner bottle.
4. Remove the drum unit while pressing the drum lock.
Shawn
Dec 31, 2010 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS 1000 - paper wrapped round hot roller
The hot roller unit is the fusser unit
Its main purpose is to stick the image toner to the paper with heat
try removing the unit when its cool
remove th paper slowly by turning the gears slowly.....give extra care not to damage the Teflon
wipe the Teflon of with alcohol to remove stains of paper....dry the alcohol properly
put everything back and u are ready to print...
if the Teflon is damaged ull need to replace this unit......
Caution.......dry the alcohol properly as this could result to fire......monitor print outs printer for the first 10 to 15 prints as to verify that everything is k....
Nov 10, 2008 | Kyocera Office Equipment & Supplies
Kyocera Mita FS-3830N Laser Printer Logo
404 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
