Question about Sanyo PLC-SW30 Multimedia Projector
Can't get images on projector, screen is blue. Changed laptop resolutions, pressed everything. Presentation is in powerpoint.
  • 75 Answers
Have you tried another computer. Are you toggling the FN and CRT/Icon image key at the same time.
Posted on Jun 05, 2010
Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Aug 27, 2009 | SharpVision XV-Z9000 Multimedia Projector
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
The projector is projecting an "out of range" message for a powerpoint presentation. I know it works b/c it switches to DVD just fine. Also, when I unplug the cable from teh comp to the projector the...
Whether you have a laptop or a desktop hooked up to this projector, you will need to adjust the resolution of your desktop to a level that the projector can handle. Without the Model number of the projector, I cannot tell what the resolution should be. I would hook it up and then lower the resolution level of the PC as see if it shows a picture. Does the projector show your desktop image on the screen? If not then changing the resolution will solve the problem.
I hope that I have provided the correct information that will assist you in the resolution of this issue.
If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 06, 2009 | Computers & Internet
Powerpoint video won't play on screen
you can try changing your overlay settings. works with some formats. or you could use the projector as main display (toggle through fn+LCD/CRT)
Feb 10, 2009 | Epson PowerLite 50c Multimedia Projector
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Presentation mode is off...
I'm going to guess that you have a wide screen Dell laptop with a 16:10 aspect ratio and a default resolution of 1280X800. The wide screen is great BUT most presentation grade projectors do not have a native (pixel for pixel) 16:10 mode. Instead they still prefer a display input with a 4:3 aspect ratio like your old square CRT or standard definition TV. Why do they prefer a 4:3 input? Mainly because Powerpoint prefers to display a slideshow in a 4:3 mode. Because of this Dell, in their infinite wisdom, created the 'presentation mode' utility in an attempt to automatically convert the VGA output of your laptop from 16:10 to 4:3 on the fly. In my experience this is an annoyance at best and at worst can seriously impact the size and quality of the projected image.
The best thing you can do when you connect to a projector is ignore the presentation mode alert and manually set your laptop's resolution to 1024X768 for an XGA rated projector or 800X600 for an SVGA rated projector. This will cause your desktop to look stretched on your laptop but will give you by far the best projection image.
Jan 16, 2008 | Panasonic PT LC75U Multimedia Projector
Image bigger than screen
Try changing the keystone. Also you may have the projector too far away from the screen. Changing the resolution on your laptop will not solve that particular problem.
Nov 24, 2007 | Office Equipment & Supplies
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
Sanyo PLC-SW30 Multimedia Projector Logo
89 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
