Question about TEKK Fitness Two Treadmill
Motor replacement I replaced the motor on my tekk 2 treadmill and forgot if the spring went on top of the motor mount or between the deck and the motor mount.
I just replaced the motor with a new one and after 30min running the outer casing is very hot, why
Posted on Apr 29, 2010
    President:
  • TEKK Master
  • 832 Answers
Usually All spacer or springs are under motor mount. Now if the spring are a cushioning feature then between deck and frame. You may just have to disassemble the unit and look, because in my early experience did the same thing and had to eliminate possibilities. for future reference always take pictures or draw a wiring diagram this will same time and agony.
GOOD LUCK!!!
Posted on Apr 26, 2010
Error 27
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Feb 18, 2014 | Precor 933 Premium Series Treadmill
Treadmill keeps stoping
Corrective Action
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
My treadmill stops wen runing on it and brings up er 27 on screen
Corrective Action
What is error 28
Precor Error 28, Temperature Too High Probable Cause 1. The lower PCA cooling fan is clogged.
2. The lower PCA cooling fan is inoperative.
3. The running belt and/or deck are badly worn.
4. The lower PCA is bad.
5. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Inspect the fan mounted on the lower PCA for dust/debris buildup. Clean if necessary, ensuring the fan spins freely. Some lower PCA's do not have a cooling fan and others may have the fan mounted on the underside of the lower PCA making it not as visible.
  2. The fan was free of dust or debris but does not spin. Make sure that the fan wiring is secure and properly connected to the lower PCA. If no obstruction to the fan and the wiring is good but fan still doesn't turn, replace the lower PCA.
  3. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions; compare the values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  5. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 28
Sep 13, 2013 | Precor C966i Treadmill C 966i
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
Quinton treadmill error 203
5. Motor.
Jun 16, 2012 | Exercise & Fitness
I have a proform 320x treadmill and it was working fine but now the belt wont move but the console is still working fine
lube the deck belt inmediately. proceed in according with the instruction manual maintenace You have some deck belt worn.2) test the drive belt for replace if necessary 3) test the input voltage motor, if there are the motor need repair 4) test the output voltage from motor board, for input voltage motor, if there are NOT, the board is faulty.
sincerely. God bless you
Apr 28, 2012 | Exercise & Fitness
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO SEE IF IT CAN BE FIXED. HOW TO ?
Remove cover at front of treadmill,4 pillips screws on each side, 2 screws at front. Lift off plastic cover. Loosen motor belt tightener at top of motor mount ,remove 4 11/16 " nuts holding motor to treadmill base, remove red and black motor wires from control board. Lift motor out.
Aug 04, 2009 | Spirit Exercise & Fitness
TEKK 2 treadmill motor problems
You lower computer board is bad. are they still in business?? If not it will be time for a NEW treadmill. name brand so we can get parts
Apr 06, 2009 | TEKK Fitness Two Treadmill
TEKK Fitness  Two Treadmill Logo
115 people viewed this question
Top TEKK Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a TEKK Exercise and Fitnes Expert? Answer questions, earn points and help others
