Question about Toshiba Satellite A45-S151 Notebook
Laptop is not turning on
The computer is not chargering even though the adapter is plugged in. I've always had a few challenges with the computer staying charged. I'm not sure if it's the adapter or the port? I see an amber light but not the green one...any sugguestions?
I cannot turn on with ac adaptor too. Have to try a few times berore power is on. Also I get stripes (vertical).
Posted on Nov 24, 2008
  • 40 Answers
Take the battery out and turn it on with only the ac adaptor, then put the battery back in.
Posted on Mar 24, 2008
6ya staff
SOURCE:
I have an Asus X53S, and I'm experiencing charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 26, 2013 | Computers & Internet
Garmin nuvi 40 will not charge
Sounds like a defective unit. You've tried everything their support people would walk you through.
Sorry...
Oct 31, 2012 | Garmin Nuvi 40
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
I have a emerson EMP385-2 can i charge it with a car charger?
MP3 players use the USB cable to charge from the USB port on a computer.
You can also charge the MP3 player using a 5 volt USB charge adapter that plugs into the cigarette lighter outlet.
These adapters are available on the Internet.
Jan 21, 2012 | Audio Players & Recorders
Hi i was using m compaq nc8000, when it turned off suddenl even though it was plugged into the ac...now when i tr to turn it on it sounds like it is going to start,the yellow charge light comes on and then...
Hi
try removing you battery and powering it up....
it could be your charger,even if the power led is on there still could be a voltage failure...i,ve sorted a few laptops like that before.....
Or it could be the charging port connected to the motherboard??
Try to gently wiggle the adapter going into the charging port and powering it on...to see if that makes a diffence....
Hope this helps...if so please take the time to rate it,as i,ve taken the time to answer you...if i can be anymore help...
Regards
Apr 02, 2011 | HP Compaq nc8000 Notebook
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
Will not turn on
Check the adapter with a multi-meter, the voltage on the connector plug should be slightly higher than the voltage that is printed on the label attached to the adapter.
OR
Borrow a working adapter, make sure it is the same or compatible to test your laptop.
Apr 14, 2009 | Gateway Computers & Internet
Hard reset and charging problems
do the hard reset again .. hold the power button down while operating the reset in the back .. keep the power button down for a few seconds .. that should bring up a display "delete all" .. you can choose to do so .. that will be a hard reset .. now if the battery is dead and the charger is not working then nothing will work for you .. you might have a bad charger .. often the end that plugs into the unit develops a broken wire inside the cable ..
the m515 wont charge from the sync cable (shame) it needs the external power adapter .. make sure the connections on the charger and palm are clean .. the power adapter is 5 volts and i think about 1 amp .. )(center pos) if you want to try another adapter .. the tip is rather standard ... also you can get a universal power adapter from radio shack that will work on just about anything .. you just plug in a suitable tip .. the tip for your palm is an "A19" .. the power adapter is "IGO" wall adapter 23-1401 model PSM08VADJ ... that seems to work nicely and it plugs directly in to the palm .. so you can work with it plugged in .. when the charger is working there should be a lightning bolt thru the battery symbol .. it sounds like you already know that .. if the battery has gone open then it may not indicate a charge .. but the unit should still work while on the charger if that is actually working ....
Apr 13, 2009 | Palm m515 Handheld
Toshiba Satellite A45-S151 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
