DC Offsets on output - protection don't allowd to switch on
Yamaha RX-V765 Amplifier - DC Offset problem. - The amplifier is few month old and it was working well.
- Now protection switch off the amplifier during booting process - in moment when speakers' relay need to be switched on.
- The amplifier is possible to switch on with bypassing protection (I have Service Manual) and in this state the amplifier is working.
- Checking the history of faults inside service menu shows DC Offset problems.
- Measuring on the speakers shows different DC offsets on all channels (-0.250 V, +0.160 V, -1.270 V, +1.650 V,....).
All supply voltage inside the amplifier are OK.
It is very strange how DC Offsets on output of all 7 channels are to high without any serious damage.
Any suggestion how to solve this problem?
(Unfortunatelly I am not in position to use warranty because in my country doesn't exist Yamaha Service Center and I need to repair it myself). Thanks
  • 185 Answers
You don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Posted on May 27, 2010
No sound coming out on any channel
I would also guess you have a flashing indicator, correct? If you do, your amplifier has DC Offset(a damaged amplifier). If this is the case, the protection circuit will not allow audio on any channel.
If you are interested in having your Yamaha repaired, please look at my website, audioserviceclinic.com. You may contact me there. Thank you.
Jul 13, 2015 | Yamaha DSP-A1000 5-Channel Amplifier
Why does my Audiolab 8000s mute light stay on?
Your amp is probably in Protect Mode, meaning you have DC Offset( a damaged amplifier). That will have to be repaired, before you can switch the unit on. If you need more assistance, or would like to inquire about repairing it, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 30, 2014 | NAD C372 Amplifier
Offset problems on both channels
Leaky capacitors in the feedback part of the power stage.
Mar 11, 2014 | Yamaha P2500S Amplifier
RX V765 switches off
power supply or something is shorted triggering it in self protection to turn off.
have a shop look at it.
Dec 07, 2012 | Yamaha RX-V870 Receiver
What does the offset light mean on sony xplod amp
THIS IS "DC OFFSET". MOST AMPLIFIER PROTECTION CIRCUITS REACT TO THIS CONDITION BY SHUTTING THE AMPLIFIER DOWN. THIS IS A CONDITION, NORMALLY BROUGHT ON BY SHORTED OUTPUT TRANSISTORS, THAT ARE TRYING TO PASS THE POWER SUPPLY DC CURRENT TO THE SPEAKERS, WHICH IN A MATTER OF SECONDS, WOULD BURN THE VOICE-COILS IN THE SPEAKERS. MOST TIMES THIS WOULD BE CHARACTERIZED AS HOOKING THE SPEAKERS UP AND OBSERVING THEM SIMPLY POKING OUT OR IN CONSTANTLY WHICH CREATES MUCH EXCESS HEAT. THIS IS WHY THE AMPLIFIER WILL SHUT DOWN TO PROTECT THE SPEAKERS. YOU CAN TRY TO DISCONNECT THE SPEAKERS AND THE RCA INPUTS THEN POWER THE AMPLIFIER UP. IF THE DC OFFSET LIGHT STILL ILLUMINATES, THEN YOU WILL HAVE TO HAVE THIS UNIT REPAIRED. ONCE REPAIRED, BEFORE REINSTALLING IT, MAKE SURE TO CHECK YOUR SPEAKERS FOR DAMAGED VOICE-COILS, WHICH COULD HAVE BEEN THE PRIMARY CAUSE OF FAILURE. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Jan 10, 2010 | Sony Car Audio & Video
I have blown the protection circuit on my yamaha rx 600d amp anyone with a clue whats needed to fix?
Hi friend,when something goes wrong in the output of the amplifier the protection circuit take place to prevent further damage could cause by DC power such as speakers or other related circuits...I think in your situation either one or both output amp stage have blown,then the protection cct turned on (not blown protection circuit!?). If so you have to check all the output transistors for short cct, if shorted you must also check all the DC bias cct nearby such as small transistors,resistors...If you are not familar with amplifier it better to find a tech as all amplifiers need a very precide repair technic , If the DC BIAS were wrong , when you turn on the power it will blow straight away! All times and cost will be waisted!
GOOD LUCK!
Tan Ta
Nov 23, 2009 | Yamaha Audio Players & Recorders
I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
Oct 24, 2009 | Audio Players & Recorders
Yamaha AV Amplifier RX V530
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Sep 09, 2009 | Yamaha RX-V530 Receiver
I have a yamaha amplifier in here for repairs, the model no is A500, i cannot get the speaker protect relay to come on, i have replaced all the transistors & capacitors in the speaker protet circuit to no...
Measure DC to ground on the output transistors to check for any offset. The protect circuit is the least likely to be the problem. Post the readings here and I'll guide you from there.
Dan
Mar 11, 2009 | Yamaha XS-350 2-Channel Amplifier
Climbing DC offset then protection mode
Hi there
Firstly, check for conductive hold down glue about the output stages. This can cause the problem you have. Or there may be a failing component somewhere in the output stage of that channel. Check for leaky transistors,diodes an capacitors. You will need to remove semiconductors to check for leakage, If you dont have alot of experience faultfinding amplifier power stages, I suggest you take it to a NAD authorised service center.
regards
Graeme
Mar 27, 2008 | NAD C370 2-Channel Amplifier
242 people viewed this question
 Grubhead
Grubhead
