I've installed a Zanussi ZWF10020W Washing Machine. The instruction manual said I should our 2 litres of water through the main detergent panel (II - the middle one), then out in a half measure of detergent and run a 90 degree cotton wash (empty drum), which I have done. I'm running into a couple of problems. The wash cycle repeatedly stalls, with the stop start button flashing green. I had to unpause it a number of times (more than 5) before it eventually finished. I then checked the detergent drawer and the powder was still there, it hadn't been taken into the wash. Any idea what is going wrong?
  • patsylagan Apr 26, 2010
    Thanks a million. Would this be the cause of the programme stalling?
  • patsylagan Apr 27, 2010
    Yes
  • Washing Mach... Master
  • 19,396 Answers
Hi.
If the detergent is still there, providing that you have used the right drawer section for the detergent (check the manual), that means that there is no inlet.
Ensure that the inlet hose at the back is properly connected, that there is pressure and that the hose is not bent or kinked.
If that is not the problem, then call the Zanussi number listed on the use and care manual. The technical support will diagnose if there is a fault.
If there is a fault it is either inlet valve, pressure switch, or timer control.
Regards.
Posted on Apr 26, 2010
  • 12,061 Answers
Http://www.washerhelp.co.uk/diy-repair-help_5.html
http://www.acmehowto.com/howto/appliance/washer/washer.php
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://www.2ndwave.co.uk/manual.html
Above is a washer "How To"
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/81c2f31bd6afd80c85256e8d005f05d2?OpenDocument
Directly above is a service manual, inside this manual, and this is what the engineers use to troubleshoot and repair, Above that, are DIY links for help in troubleshooting... Just perform the procedures, and you will soon, be able to repair, your unit. Please go to ALL links, that way you WILL be able to get a complete picture.
My zanussi us leaking water as soon as it starts to fill. I've cleaned the pump and detergent door but no help. It's leaking from underneath somewhere
It sounds like there may be a split in the fill hose! Go to the Zanussi web sit and you should be able to buy one for a few £££. Take the top and back off your machine and you should see the hose if you follow the pipe where the water connects.
Dec 16, 2014 | Zanussi Washing Machines
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
Zanussi zwf10020w washing machine wont fill with water
make sure that your water hoes connector (with the blue plastic knob) on top of the blue knob there is a screw,, undo the screw and take the plastic knob off,, with a pair of pliers and turn it half way with the machine now about to start,, that way you will know if it is that,, but it sounds like it is that.
Oct 18, 2012 | Zanussi Washing Machines
Where would I find a replacement detergent drawer for a Zanussi 1055W washer/dryer?
http://www.ebay.co.uk/itm/Zanussi-Washing-Machine-Washer-Dryer-WDA1055W-Soap-Tablet-Detergent-Drawer/162547763876?hash=item25d89a0aa4:g:fsAAAOSwuxFYzP3t
Nov 06, 2017 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
Water left behind in filter reservoir
There is always water left in the filter at the end of the cycle. Tjis is unlikely to cause the smell problem though.
If you do a lot of 40 degree washes and use a biological detergent you can get a bacteria build up in the appliance which is very unpleasant.
To rectify this, run the appliance on a 90 degree wash with two spoonfuls of washing soda in the soap drawer. Allow the program to complete the cycle( no clothes though) and repeat once more.This should help clean the appliance.
Several appliactions may be required if smell persists.
Nov 16, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Water levels
Probably the nivauchamber is clogged of lime or something. Or you are overloading the machine
Jan 31, 2008 | Zanussi ZWC1300W Front Load Washer
The fabric softener doesn't go in...
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Nov 12, 2006 | Zanussi W1242W Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
