Question about Apple iPod MA446LL/A MP3 Player
No sound I can not get any sound from the Ipod
  • holters Jun 15, 2008
    I have the same problem. the ipod plays on screen but no sound comes out.. I tried pluggin into car player which uses the bottom outlet and that wouldnt play either...
  • leetracee Jun 25, 2008
    All of a sudden i have no volume from earphone jack or USB on the bottom of my Apple iPod Video 30 GB Black MP3 Player. I would so appreciate someones help on this.
  • 40 Answers
First off, check the volume...easy enough...
if not, the ipod 5th gen's are notorious for the headphone jack pins getting bent and broken...if this is the case, you need to buy a new headphone jack and replace it (there are many websites that you can buy/offer a replacement service)
Posted on Mar 24, 2008
I have no sound on my ipod and apopup say generic volume running
Damaged hardware is responsible for the most obvious iPod sound problems.
In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it right before your sound stopped working.
Hold your finger over the top left corner of the application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores.
It may take several minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work.
Have your iPod with you.
Aug 01, 2013 | Apple iPod Audio Players & Recorders
Tip
How to make the sound of the iPod Better
<p>Take your music with you on your iPod, portable media player from Apple. Depending on iPod model can hold between 500 to 40,000 songs. No matter how small or large your music collection, not content with mediocre sound quality while enjoying your music. Using a combination of hardware and software settings of the iPod add-ons to your iPod pump up the jam like never before. <br /> <p><br /> <p>1. Change the iPod music equalizer. These changes and increases the sound from the iPod to better match a specific style or genre of music. Press "Menu" on the front of Click Wheel iPod. Go to "Settings" and press the middle mouse wheel. Scroll down and select "EQ". Select the type of music you listen to (e.g. "Rock") and press the middle button of the Click Wheel. <br /> <p><br /> <p>2. Sound set control function for all your iPod music playing in the same volume as surprising increase or decrease in volume between songs. Click "Settings" from the main iPod menu and choose "Sound Check" to turn it off. <br /> <p><br /> <p>3. Use headphones instead of earphones that came with your iPod. While the earbuds feature enough for everyday use, audiophiles cannot enjoy the limited range of buttons compared with headphones bigger and more powerful. Additional benefits in some models of headphones, such as blocking noise canceling ambient noise, also can help improve your iPod listening experience. <br /> <p><br /> <p>4. Connect the iPod to a stereo amplifier or iPod compatible. This adds low-range and headsets that many cannot create and is ideal for cases where you connect your iPod to share with a group sounds like a party. <br />
on Aug 09, 2011 | Apple iPod touch
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
Ipod classic has no sound
Damaged hardware is responsible for the most obvious iPod sound problems. In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty. All iPods have a one-year warranty according to Apple's website. Software problems can also affect your audio. For example, downloading a non-certified Apple application can stop your sound from working correctly. Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound. If that set works, your old headphones were the cause of your audio problems. If your iPod still doesn't work, proceed. Open iTunes. Plug the iPod into your computer with a USB cord. Click on your iPod on the left-hand menu. The iPod will be listed under the name you assigned it when you first set it up. Click the "Restore" button on the menu. Leave the iPod alone while it restores. It may take several minutes. Test the sound once the restore is complete. The iPod syncs after restoration. Once the sync is complete, the process is over. Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work. Have your iPod with you. Hope it helps
b>
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
My ipod wont play on my AVIC F910BT
I don't know if you fixed it already this iPod sound trouble, but I got ot also and found how to fix this trouble.
In fact there's a setup to do and mention in the User Manual (page 89 on the english one) the AV1 config should be selected as iPod
Using an iPod (iPod) Starting procedure
Connect your iPod.
No sound or video output if iPod is selected
as AV source, check the setting in “AV1
Input” on the “AV System Settings” menu.
Dec 25, 2009 | Pioneer GPS
With my ipod dockes I am getting a distorted sound
Did you get this solved??
I am having the exact same issue!
Oct 21, 2009 | Bose SoundDock® (Black) Docking Station...
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
Jul 23, 2009 | LG RZ-17LZ21 17 in. LCD Television
No sound from my 30GB ipod in the car and Bose sound dock
It sounds like an issue with the internal motherboard and possibly the audio jack. I'd reccomend taking it into a local apple store to have them fix it or contacting them via their support website here. Also you may want to consider their price quotes vs purchasing a new one when you talk to them.
May 24, 2009 | Apple iPod MA446LL/A MP3 Player
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
http://store.ifixipodsfast.com/ipod-parts-/-installation/ipod-video/ipod-video-headphone-jack-/-hold-switch/prod_69.html
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
102 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
