Agere modem 2.0 no dial tone message
Agere modem 2.0 suddenly no connection- no dial tone message
    Sergeant:
    Champion:
  • 203 Answers
If its working properly before, try to remove the wirings and clean it a little then try it again, possibilities is its wires didn't contact properly.
Posted on Apr 26, 2010
No dial tone
Make sure that the dial tone is coming from the wall jack
Mar 19, 2011 | Rosewill RNX56AG Agere 56Kbps PCI Bus...
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
Hi, to every one. I need to disable a dial tone from my laptop modem to make a data call to plac from omron. When i call from local because the sound is one tone, it dial but when i call from standard...
WELL I SOLVED THEE PROBLEM BY INSERTING A "x3"AT COMMAND IN THE MODEM ADVANCED SETTINGS, AND I MADE A CALL FROM STANDARD PHONE LINE.
THE IDEA WAS THAT I MAKE A BLIND CALL, TO PLC VIA GSM MODEM. THE ATX3 COMMAND MAKE BUSY IF THE LINE IS BUSY OR BLIND CALL IF LINE IS FREE.
WELL THAT'S MY SOLUTIONS,
Nov 19, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
Error keeps saying
install the modem drivers properly
Aug 31, 2009 | Agere (DSLU56KPCI) Modem
I have an agere modem that came with toshiba satellite laptap the modem is set for US standards I am currently based in Greece -- do i need an initialization code to get it working?
You don't need to provide initializing code based on the country. Create your new modem connection using new connection wizard. Provide it with username, password and telephone no. to dial. Select your agere modem to use for dialing. It should work. If it not contact your telephone service provide to know about any initialization code needed to dial and connect into their network.
Aug 04, 2009 | Computers & Internet
HP pavilion dv5-1125nr notebook, dial up modem is not working
Save yourself alot of grief. Purchase a PCMIA or USB modem and your done. A very inexpensive fix. I am a certified HP Master tech and I will tell you that HP does have some consistent problems withg their modems. If you can spare a few bucks go to www.driveragent.com and try to locate an updated driver.
Jul 30, 2009 | HP Pavilion dv5-1125nr Notebook
Have problems connecting with my ISP
right click on my computer and got to manage. then there click on the driver u want to update, click on update automatically.
if it not help then visit:
moz-screenshot-3.jpghttp://tinyurl.com/m7ghqz
Jun 15, 2009 | HP Compaq Presario SR2011WM PC Desktop
Agere All 56K Modem
I have checked the telephone line, it is working alright and it is sure that I have plugged the line into IN port.
Oct 19, 2008 | Agere All 56K Modems: 56K V.92 Lucent/...
Modem stopped working
Well its sounds ike the modem may poked ut lets assume it is not perhaps yo have doube checked your conection is correct if it is TRY ANOTHER modem because they are known probems for your coonections especially dialup are you meaning this?
Jul 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
