Question about Lite On LVC-9016G DVD Recorder/VCR
Firmwae upgrade & dvd's don't play on other players
I am not a tech person. How do you upgrade the firmware? and why is this necessary?
Will this fix my problem of finalized dvd's not playing on other players?
    Problem Solver:
  • 13 Answers
You can download the firmware and burn it to a CD, not a DVD. I don't know what burning software you are using put with Nero you would choose to burn it as an ISO, This is standardized way of burning identical images of CD/DVD. You should be able to then put the burned CD with the updated firmware into the unit and it should automatically update. You can watch the TV screen and see if it prompts you for any info but I do not believe that it will. Good Luck.
Posted on May 31, 2008
SOURCE:
Ciao i will buy a Technics SL-DZ1200 used I want to know if it's necessary to upgrade the firmware. Also, i want to know the latest release of the firmware in distribution Is The latest...
the firmware depends on display. if the display does not supports MP3, firmware upgrading will not help. most of the time upgrading firmware will not help playing MP3.
Aug 25, 2011 | Technics SL-DZ1200 CD Player
Can I make my DVD player play region 2 DVD's?
Depending of your DVD player brand you may or may not find on the internet some firmware upgrade. Upgrading the firmware can turn your DVD player in region free player so you can play any region DVD. I did that with a no name brand and was succesfull. So, I wish you good luck!
Jan 27, 2011 | Televison & Video
Playing the soloist on panasonic dmp-bd80. get
Try updating the units Firmware:
Firmware is software that exists usually on chip or flash memory within a larger piece of hardware, such as a Blu-ray player. Firmware can be upgraded to fix a technical problem with the player or to meet new industry standards.Firmware updates can be applied either by downloading them directly to your device, or by disc installation.
Jan 19, 2010 | Panasonic DMP-BD80K Blu-ray/DVD Player
It freezes when playing a blueray movie. it seems
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. Most often, the firmware problem is JAVA related and will not let the menus load at all, but freezing during playback has also been reportedly fixed with the firmware upgrade.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 19, 2009 | Sony BDP-S350 Blu-Ray Player
Stopped playing Blu Ray discs, but still plays DVDs...
Have you tried upgrading your player's firmware? I have the same model, and had similar problems playing newer Blue Ray Discs.
I hope that helps.
Dec 12, 2009 | Sony BDP-S350 Blu-Ray Player
I recorded onto DVD-R discs and then finalized but they wont play on my dvd? how can i get them to play ? i usually buy DVD RW
Some dvd players cannot play certain types of discs. You could check to see if the manufacturer of the dvd player has a firmware update to fix this problem. Older dvd players have trouble playing some of these discs. Most newer dvd players do not have issues and have upgradable firmware to adjust for different formats. Does your burner also do DVD+R discs? Maybe try using those and see if it plays on your dvd player.
Sep 05, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Samsung bd-p1200 won't play new "quantum of solace"
I too had this problem with Qauntum of Solace, I could get past the teasers and the warnings but when it gets to the main menu I select PLAY and it just stops at 00:00. The firmware upgrade fixed it! However I had to make a CD because the LAN method said I already had the latest version. I downloaded Ver 2.5 from Samsung support site - ( http://pages.samsung.com/us/bluraysupport/support.html)
Then I needed to get Nero Burning ROM software (windows version) to burn an IMAGE of the .ISO file (I use a Mac and just burning the file onto a CD didn't work) You have to follow these instructions to the letter - ( http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=1488556&CDCttType=FM&ModelType=C&ModelName=BD-P1200&VPath=FM/200710/20071012103832890_BD-P1200_CD_Update_Process.pdf )
Finally the player recognized the firmware and did the upgrade to 081119_T22F_0924.07_XAA
Voila, QoS now plays without a hitch.
Apr 06, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
Blue ray disc broke my dvd player
Unplug/replug the player - try again.
Also, get a firmware upgrade disc from Sony's website to try and reload the firmware.
Sep 04, 2008 | Sony DVP-NC615 Multi-disc DVD Player
Philips DVP3140/37 DivX player does not play certain DivX files. I have the region code as 0. For some DivX files it plays the video but the audio does not work. These work fine on computers.
Have you tried upgrading the firmware.
Check first the firmware of your DVD by opening the tray, then press 37 on the remote, and jot down the version of the firmware, then try to find an upgrade to your version or an improvement to it that fixes the original trouble with some DivX files.
Sep 02, 2008 | Televison & Video
Won't play dvds.
Hi, All. I found this discussion based on a Google search because I was having the same exact problem with playing Superbad on my Philips DVDR3400 after renting the movie 3 times and confirming the DVD played on my computer, etc. The good news is I was able to fix this problem. Go to Philips support at http://www.support.philips.com/support/html/index_us_en.html From that link, enter the model number of your DVD player into Search. Select your player from the list that comes up, and on the next page select "software & drivers" link at the left. This will take you to the firmware upgrade for your exact model which updates the software that runs your DVD player (also, when trying to find your exact model..such as mine was DVDR3400/37...you can find it on the label on the underside of your DVD player or it is on a sticker on the back side of your user manual). This takes you to both the link for the software download as well as detailed instructions on how to do it which are very clear. That includes how to use your remote to check that the version you will upgrade to is newer than the current version on your DVD. This was quite easy so long as you are comfortable with downloading the software to your PC, unzipping and then ripping to a recordable CD disc. You will then put that dics into your DVD which will read the files and upgrade itself. The whole upgrade process on the DVD itself took about 5 minutes. When it was done rebooting after it upgraded, I powered it off/on. Then I played Superbad, laughed and had a good time ;)
Dec 05, 2007 | Philips DVDR3390/37 DVD Recorder
Lite On LVC-9016G DVD Recorder/VCR Logo
202 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Ekse
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
