I want crt looking screen in ma acer lcd monitor...how can i do that? plz help me
I installed sound driver but error will occur like that (install realtek HD driver failure!![error code:0*E0000227])
Posted on Apr 26, 2010
I m having acer ac515 15" crt monitor. its CRT is got damaged. i want to know which crt will be applicable for that becoz the existing mounted CRT is not visible ( which specification it is having is not...
Any crt monitor will work with your computer.
I suggest you get a LCD monitor instead and a larger screen than 15".
LCD screen take up less desk space and are lighter and more energy efficient.
May 22, 2010 | Acer AM 501 15 in.CRT Conventional Monitor
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
Can't change W to H ratio
use another monitor crt not LCD. adjust first the resolution. then connect again to your acer LCD. or you can auto config your acer from menu.
May 29, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Red line
The display cable in your LCD monitor must be replaced.
If you are feeling adventourous then you can look on ebay for a display cable to install but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you can get the part then I would take it to a local Tech to replace it.
Mar 14, 2008 | Acer AL1916W 19" LCD Monitor
Thin red vertical line length of screen(right side)
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 20, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer LCD AL1716W Monitor shows lines
use 1440 x 990 resolution, the ratio of the monitor is 16:10
Dec 27, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Help me with ma monitor
Being a 21" CRT monitor (old tube type) it is going to be cheaper to buy a new LCD flat screen than to fix this one. Best bet if you do want to fix this, is to take it to a tv repair shop and let them work on it. You have not given enough information to give a good educated response to what might be causing this issue. Good luck.
Aug 18, 2007 | NEC AccuSync 120 CRT 21" Monitor
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
