Question about Whirlpool Duet GHW9150P Front Load Washer
My washer does not drain all of a sudden - Whirlpool Duet GHW9150P Front Load Washer
  • 3 more comments
  • Anonymous Aug 09, 2008
    my washer goes thru the regular wash cycle, then when it gets to the rinse cycle, spins out, then stops like its suppose too, door does not unlock, then it suddenly begins to refill with water (2 gallons or so) and "sud" appears and sits and
    ticks
  • adamsbb Oct 17, 2008
    I have the same problem, except mine does not refill. I had found coins in the coin catch area, removed them, and it drained for a load or two. Now, it does not drain again.
  • rlambrec Nov 28, 2008
    The machine goes through the whole cycle including spin, but the water does not drain. Is there a pump that pushes the water up? because if I take the drain pipe and lay it down the water empties - gravity. Thanks
  • vickithetim Dec 13, 2008
    I'm having same problem, machine won't drain after cycle. It's a hoover HNWL nextra 3126 washer/dryer. Is there a way of fixing this?
  • Ron Coons
    Ron Coons May 11, 2010
    whats the make and model number of possible??
    Scholar:
  • 42 Answers
If you're washer is working (water in-coming, then agitiating, but does not drain/spin at the "spin cycle"; the typical problem is either the door/safety switch or the electric water pump (belt drive machines). I would test the door switch for continuity; replace as necessary.
Posted on Jan 25, 2009
  • Maintunivers Jan 26, 2009
    I would also recommend check your water pump for obstruction. Coins or other debris (necklace, socks, shoe laces, etc. can block the impeller inside the water-pump and prevent draining.
    The water pump can be accessed through the outside bottom or rear access panel(s). The pump should be electric, white plastic with 2 black hoses connected to the pump (Tub to pump and pump to rear drain hose). I would disconnect the larger black hose that leads from the tub/drum to the pump, then insert my finger into the water pump and remove any obstruction, while rotating the impeller manually (small rotating fan type feel).
    Caution: Disconnect power before servicing. Also, any sitting water in the unit may pour out when disconnecting the hose; you may want to relocate the washer to an outside area. I would recommend to cover the pump or other electrical components with plastic to prevent water from getting on them. Be sure to hold-on to the hose and direct the water flow outside the washer cabinet when disconnecting the hose; as a decent amount of pressure and water flow may come flowing out.
No idea
Posted on Dec 14, 2008
My Hotpoint first edition WMA goes full cycle but will not empty.
Posted on Nov 21, 2008
Washer doesn't spin drain
remove the drain hose at the back of the washer and check that the filter is not blocked.
Feb 24, 2012 | GE Washing Machines
The washer were washing all of sudden it stop
Clean out your drain pump. It has lint and debris in it. "ld" is long drain.
Jul 14, 2009 | Washing Machines
Washer Impelling into Hot Water Line
this sounds impossible,hold old is the washer? how long are the hoses to the washer?is it the temp pressure valve on the heater that bursts? can you hear the water draining out the drain pipe, this machine don't go into spin till the water has been drained.
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Miele dish washing machine no drain and it sudden stop after flushing the water
If the machine does not drain, then follow th suggestions below:
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
From repairclinic
Sep 30, 2008 | Washing Machines
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Washer not spinning
check the sensor switch located underneath the the top washer where the door closes , make sure contacts are clean (or align for magnetic SWITCH)
May 05, 2008 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal De
