Question about Canon iRC3100 Printer
How can I replace the Canon IR3100CN Drum unit.
I have problems with Canon IR3100 CN. I get the following messenge:
Error Code: E000020-0081.
I have been told it is to do with the drum unit. Can you please tell me whether it is true and if yes how can I clean it.
Thank you.
  • 1,219 Answers
Hi, yes it is drum RELATED error, but before changeing the drum, clean the drum sensor. When you remove drum unit, inside of copier in drum unit place, from left side, uperr in the middle you have small sensor - Clean it!
Then try again.
If not tell me the exact error code eg. E 020 - 01A2 or?
It may be problem also in developing units.
Posted on Apr 26, 2010
How to clear an error fo canon copier ir 6800 cn with an e000061-0001
A E000061 is a drum potenal problem. It means the drum is not charged up correctly. It could be as simple as replacing the two post corona wires and cleaning the grid or making sure the primary charge unit is installed correctly. It may also, be a broking grid or corona wire > you may have to replaced the primary charge unit??? It could also be the drum potenal sensor or the DC controller or the drum..... I'd go for the simple stuff first and you can not clear the problem till the problem is fixed > Before I forget, you can also, turn the drum potenal off in service mode... It's just a band aid, it will not solve the problem..... Good Luck
May 05, 2012 | Canon Office Equipment & Supplies
Canon ir3100cn giving me error code E000020-01a9. how can I go about it?
Hello luvmor. The code means the that when the copier tries to calibrate its colors (gradation) it cant get the yellow to calibrate.This almost certainly because the yellow drum has reached the end of its life.On this machine,it is not as simple to replace the drum unit as it could or should be.Newer machines are far easier to perform a drum replacement.I would have to recommend a trained technician to perform this procedure.
Apr 21, 2010 | Canon Office Equipment & Supplies
Canon IR3100CN has a error message E0000200081 any help
E020-081...
Dirty Drum patch sensor OR the drum has reached 100% of it's life.
iRC3100 drums NEVER go past 100%...once they reach that magic figure in the counters then it's time for a drum replacement.
If you know how to access service mode then check under:
COPIER>DENS>P-SENS-P and make sure that the figure is around the 500 mark...if it's below say,250 then that indicates that the drum patch sensor is having trouble reading correctly and may either need cleaning or a new drum unit.
Jan 29, 2010 | Canon iRC3100 Printer
Hi I have a cannon copier IR3100CN that has an error message E000012-0001 have you any idea what the problem is and what I might be able to do. Thank you
That code refers to the drum unit been unable to rotate. You may have a seized drum unit - remove and inspect - or the drum drive motor is faulty.
Dec 16, 2009 | Canon Office Equipment & Supplies
Showing error code E000020-01a9 on IR 3100CN
this code is for the density of the yellow toner, most likley has a bad drum.
Aug 13, 2009 | Canon Office Equipment & Supplies
Canon IR3100CN E000070-0002 During start up the code pops up and the copier don't work.
you have a broken ITB unit,
its a pretty common error code on these machines, you need to replace your ITB frame and it prob has broken the belt also
Jun 04, 2009 | Canon imageRUNNER C3200 Copier
Error code
HI
Machine error E0020-01a9 is developer problem
Dec 13, 2008 | Canon imageRUNNER C3200 Copier
Re: canon ir3100cn E000020-0081
I just spent 20 min typing a detailed post why the e225 is already fixed and the e020-0081 is common and means the drumm patch sensor is dirty and then the web site erased it. Grr.
The drum patch sensor shines down at about the 11 o'clock position halfway down the drum. Remove the drum taking care not to scratch it or the transfer belt and clean the sensor window.
If the problem re-occurs then you may need new developer units.
May 06, 2008 | Canon imageRUNNER C3200 Copier
Canon iRC3100 Printer Logo
1,554 people viewed this question
old marine
old marine
