Gigabyte GA-8IR533 Motherboard
Problem for Gigabyte GA-8IR533 Motherboard
Changing motherboard
By Green1 - usenet poster
Hiya,
I'm about to gut my current desktop box and transplant the old mobo,
processor and RAM with a Gigabyte GA8IR533, Celeron 1.7GHz processor and
728Mb DDR memory. Everything else is the same.
Will there be any problems in doing this or will RedHat automagically
recognise the changes and do what it needs to do?
Advice needed before such drastic surgery...
TTFN
Paul
Solution #1
posted on Aug 07, 2005
Not Rated)
Joey2
Rank: Apprentice
Rating: 0%, 0 votes
I upgraded from a 486 ISA based machine to an Athlon XP.
After moving the hard drive to the new computer, the upgrade procedure went
something like.
1. boot machine using old kernel,
2. recompile kernel
3. put new kernel in /boot
4. run lilo
5. Boot new kernel
5. Repeat from (2) to sort out minor problems like, APM support.
This was with my heavily hacked Slackware install.
Note that I didn't have full functionality when I booted the old kernel - I
had no PCI
support and therefore no network card just for starters...
/john
Was this helpful?
Yes
No
Solution #2
Not Rated)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
Seconded. As long as you're still running a RH-supplied kernel and it
includes support for your IDE hard disc controller (assuming you're using
it instead of a SCSI controller), then it should all go smoothly.
This isn't Windows. ;-)
Best to take a backup of important stuff beforehand to be on the safe side
though! ;-)
Best Regards,
Alex.
Alex Butcher        Brainbench MVP for Internet Security: www.brainbench.com
Bristol, UK                        Need reliable and secure network systems?
PGP/GnuPG ID:0x271fd950                           <http://www.assursys.com/>
Was this helpful?
Yes
No
Solution #3
Not Rated)
Reynolds
Rank: Apprentice
Rating: 0%, 0 votes
I don't think you'll have any problems.  I don't think there are any
changes necessary to Red Hat.  There's a small chance of DMA not
working without fiddling, but it's small---unless you've compiled your
own kernel, you've probably got one which has suitable support for the
various chipsets.
If you want sensor support (CPU temperature, fans, etc.) then you'll
probably need to do a bit of reconfiguration.
Was this helpful?
Yes
No
Popular Solutions for Gigabyte GA-8IR533 Motherboard
Questions and Unsolved Problems for Gigabyte GA-8IR533 Motherboard
Do you recommend Gigabyte GA-8IR533 Motherboard?
Answer
Answer
problem with pci device and ethernet port on mother board ecs 945 gct hm
Answer
Hi, i have a technical problem with one of the slots of the mainboard (grapic card). I like to buy a... (More)
Answer
how do i unlock channels on an ntl set top box?
Answer
Erroe asking me to return tray to normal postion and press reset buttun resume printing
Answer
i have anorthgate motherboard SV266M and i need drivers...video and netowrk etc etc
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gigabyte GA-8IR533 Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
