Question about Sony Cameras
When i pluged in the memory stick in my camera it display formate error
    Guru:
  • 1,705 Answers
Try re-formatting you stick, it will be a menu option on your camera.
If that doesn't work, have you got a friend or relative with a Sony camera, if so, try and re-format it in theirs.
If that still doesn't work you've a problem with the memory stick.
Posted on Apr 26, 2010
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
You will need to format the card in the camera. This will erase it so download any pictures first using a card reader if necessary.
Apr 26, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Format error displaying on screen when i turn on camera,
Format error,
Press menu in camera and select Format in list to format memory stick, click OK.
Problem will solve.
Jul 04, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Error formatting memory is displayed when camera is on
hey! I've had the same problem, and all you have to do is go to the "format" menu of your camera and click on ok when it says that all data on memory stick will be erased. The message will then disappear. Only problem, if you havent saved your pics yet, you'll lose them.... :(
Jun 04, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Format error
i have orignal memory stick but i am also getting same error.. have forated stick on camera but no effect on error. so plz can u tell me how can i format my memory stick ... SONY GURU
Jun 07, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Need Help FD95 Memory Stick
Not all fd 95 are memory stick compatible !
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Cameras Logo
53 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
