Question about Pioneer VSX-518-K Receiver
My pioneer vsx-519V-k amp keeps turning off when I, turn the volume above 50 db
  • 88 Answers
Check audio ic & component like resistors & capacitors. good luck!
Posted on Apr 26, 2010
Pioneer VSX-60 Volume Decrease each 2 min
it's a somewhat common problem with that model. It needs a new cpu board.
Apr 21, 2014 | Pioneer Elite VSX-60 7.2 Channel Network...
Pioneer vsx 519v... My amp wont let me select adv surround?
does in show anything on the display when you press the advance surround button?
Jul 08, 2013 | Audio Players & Recorders
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Oct 28, 2012 | Pioneer Vsx 519v-k 5.1 Home Theater 550...
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Turn it on and it turns back off
it sound like the dsp ( digital sound processing) board is not working, take it to your nearest pioneer shop and get them to take a look at it, hope this helps
Dec 26, 2011 | Pioneer Audio Players & Recorders
Hi I want to add 2 extra speakers (for outdoors) to my Pioneer VSX-519V and see in the manual that I require a separate amplifier. Why is that necessary & if so can you recommend one please ? Thank...
Technically, you dont need an additional amplifier to run another set of speakers. This amplifier has a second zone output option. What you need to do is connect your outdoor speakers to the second zone on the reciever, than you can turn it on and select the desired source from your remote.
Jan 03, 2011 | Pioneer Audio Players & Recorders
My pioneer vsx-519V-k amp won't turn on. Just bought it about 4 months ago. we were using it with music and a microphone when it conked out and won't turn on anymore. Have checked the power source, the...
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
Jul 06, 2010 | Pioneer VSX-518-K Receiver
Pioneer vsx 5900s cuts out when turn volume up
most amps do that if too high in volume.but check yr speaker ratings and connections
Jul 04, 2010 | Pioneer VSX-D509S Receiver
Receiver won't let volume go higher than -7 dB
Actually, -7 db and above woul be quite load.
Anyway, I am not very familar with the Pioneer GUI auto setup. But, am aware of how AVR are set-up.
If you have set up the home theatre by auto/manual setup then please check the channel levels whether any of your channels settings is at +7.0db.
If so, reduce this setting where it more +7.0, then you would be able to raise the overall main setting from the volume control to go higher than -7db.( by as much as you've lowered the particular channel setting)
Please do let me know if this helps.
Apr 29, 2009 | Pioneer VSX-1018AH-K Receiver
Pioneer VSX-518-K Receiver Logo
1,026 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
