Question about RCA RCR350 Remote Control
Three in one RCA U'remote - four digit codes for symphonic tv? code 1189 amost
Three in one RCA U'remote (RCR350) - four digit codes for symphonic tv? code 1189 only'one that almost worked.. just for off & on.. the rest dont..
please help..
  • hoi-ma Mar 24, 2008
    three in one RCA U'remote (RCR350) - four digit codes for symphonic tv? code 1189 only'one that almost worked.. just for off & on.. the rest dont..
    please help..
  • 74 Answers
Try the code search option that tries 100 different codes. If you do not have the manual for the remote, then you can get it here for free:
http://www.replacementremotes.com/tvcodes/index.html
Posted on Mar 25, 2008
SOURCE:
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
Sep 25, 2015 | Symphonic Televison & Video
I need to know the code and how to program this remote for a Symphonic TV
0276,0183,0194,0264,0714. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 09, 2013 | RCA RCR311B Remote Control
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Dec 24, 2010 | Funai Televison & Video
I need GE 24914 Universal Remote Control codes for symphonic tv
Four digit code are
Three digit codes
024, 033, 053, 189, 198, 227, 456
Three digit codes (purchased before August of 2002)
033, 038, 189
Thanx
Jul 26, 2010 | Universal Remote Control GE174Universal...
Program my symphonic tv
Here are the steps on how you will program your remote control to your Symphonic TV
1. Manually turn on the component you want the remote to control.
2. Press and hold the TV key. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, and the process is exited.
4. While holding down the TV key, consult the list for the four-digit code that corresponds to your TV and use the number keys
(0-9) on the keypad to enter it. While you are pressing the
numbers, the illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the TV key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct
procedure for Direct Code Entry. If the illuminated ON•OFF key blinks
four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the process from step 2. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the TV key is programmed with the correct
code for maximum functionality, test the TV. Attempt to
control a variety of the TV’s functions with the remote. If some of the features of your TV do not work, try programming the remote with a
different code in the list until you find the code that allows the remote to control the majority of your TV’s functions. Different codes can provide
different levels of functionality.
7. Remember to enter the code for future reference.
The codes for Symphonic TV are as follows:
1026, 1033, 1038, 1046, 1155, 1189
Jun 13, 2010 | RCA RCR311B Remote Control
What is the code for a symphonic tv and a rca remote. I also need insructions on how to program the remote that works with my tv. I lost the instructions
These are the steps on how to program your RCA Universal Remote Control to your Symphonic TV.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV button. When the TV button flashes proceed to the next step.
  3. Enter the three digit code. In your case, the code for the Symphonic TV are 064 or 076.
  4. Release CODE SEARCH.
  5. With the TV on, press another button, for example CHANNEL UP. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-5 using the other code number.
Jun 12, 2010 | RCA Universal Remote Control
How to program for panasonic tv?
from http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR350
Code 1003 for Panasonic TV
Code 1054 for Panasonic TV
Code 1062 for Panasonic TV
Code 1109 for Panasonic TV
Code 1170 for Panasonic TV
Code 1248 for Panasonic TV
SEE ALSO
RCA Universal Remote Control Programming Codes
http://www.thompsontv.com/rcarc.html
Good Luck!
Apr 13, 2010 | RCA RCR350 Remote Control
I have a rca universal remote control and I need a code for a panasonic tv
Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV
Aug 05, 2009 | RCA RCR350 Remote Control
Symphonic codes for rca rcr450
Download the manual and look at the back pages =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Codes for Symphonic TV on Page 39
Symphonic TV 1026, 1033, 1038, 1046, 1155, 1189
Codes for Symphonic TV on Page 40
Symphonic VCR 2026
Good Luck!!
Jan 01, 2009 | RCA RCR450 Remote Control
Advent code list
Phillips tv: 1002 1003 1004 1008 1012 1019 1062 1068 1069 1075 1076 1087 1219 1238
Samsung tv: 1004 1005 1006 1012 1013 1015 1017 1019 1082 1104 1105 1106 1171 1172
Symphonic tv: 1026 1033 1038 1046 1155 1189
Toshiba tv: 1000 1048 1072 1105 1109 1118 1160 1190 1241
RCA tv: 1000 1003 1005 1006 1019 1054 1096 1098 1099 1100 1101 1102 1103 1129 1179 1188 1190 1203 1240 1252
Citizen tv: 1004 1006 1008 1016 1038 1105 1132 1171 1174 1177 1191
Panosonic TV: 1003 1054 1062 1109 1170 1248
Sep 19, 2008 | Recoton Advent Advent ADR-560 Remote...
RCA RCR350 Remote Control Logo
2,725 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
