Question about Sony Cyber-shot DSC-T100 Digital Camera
Vibrates when switched on, noisy
Dropped camera accidentally, now vibrates when switched on, unsteady shots, and noisy motor sound.. best way to fix it?
  • 87 Answers
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on Apr 29, 2010
  • Adi Ingel
    Adi Ingel May 02, 2010
    you are welcome, glad you could get this great cammera back to working
Just wanted to say thank you. This was the EXACT problem my DSC-T100 was having, Really not to bad of a fix if you have the right size screw driver, and are careful not to get any finger prints or grease on the CCD and the lens in the stabilizing unit. Awesome!
Posted on May 01, 2010
My digital camera vibrates
Hi! Make sure you didn't accidentally turn off the "Steady Shot" mode. You can change this mode through the ''Menu'' button. If this is not a reason of vibrations, use manual for your device. You can try to find it here
Mar 07, 2014 | Samsung TL Cameras
Why does my Sony cyber-shot model DSC-T70 vibrate and what can i do about it?
There is some steady-shot mechanism in camera lens that start vibrating due to some reason, this mechanism will be replaced to fix your camera issue.
It is not user level fix so take it in local camera repair shop.
Sep 04, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Sony dsc-t70 camara vibrates when turn on
it's actually a failure with the lens mechanism, I just experienced the same situation....Sony has another T20 that they had the same situation with and they offered to fix the cameras until July 2011..currently checking if Sony will fix this defect in this T70
what you are experiencing probably is best described by this article:
www.sonyinsider.com/.../dsc-t20-cyber-shot-camera-vibration/
Oct 25, 2009 | Sony DSC-T70 Digital Camera
Nikkor 70-300 f/ 4.5-5.6 AF noise followed by "click"
Well most AF mode do make a noise of some sort because its trying to adjust for a clear shot. I've played with several cameras and their features and notice this is a common thing, its usually the camera. But if your really worried about it and it does bother you, just take it in for a service. Maybe because of you dropping it several times, the noise is more louder now.
Sep 08, 2009 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Fridge sounded like a car revving
Check the compressor fixation are okay.Normally it should be on rubber parts fixed to the bottom.If one of them is not fixed it can vibrate.
Jun 30, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Sony dsc t20
I found the following shortly after posting my similar problem. It looks like Sony will fix the camera:
http://www.photographyblog.com/news/sony_cyber_shot_dsc_t20_problem/
Oct 17, 2008 | Sony Cybershot DSC-T200 Digital Camera
Problem in Sony DSC T20
Call sony to see what they can do. Other than that their isnt many repair shops that are much less than what they quoted you. Or if you are good with mechanics it isnt hard to change the motor. Just purchase the exact same camera, a broken one with a different problem, off ebay or something similar and exactly how you take the motor out of the parts camera is how you would with yours.
Jun 03, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Camara vibrates
Hi kundaj,
I wish there was a simple solution, but sadly there isn't.
It's the camera's lens motor system that's gone bad. Best thing you can do I think is get a replacement if you can and then extend warranty.
Cheers
Mar 24, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
T20 camera start vibrating when switched on
The motor is shot, you will have to replace it. I would call sony and raise HE** will them, there are alot of these posts.
Mar 14, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot  DSC-T100 Digital Camera Logo
800 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
