Question about Canon imageRunner C3100N Copier
IR 105 E012
Replaced so far: DC Controller, Drum Drive, Drum Shaft and Bearings. I have separated out the wires and connectors and cut all wire ties. Wires ohm out fine. The machine warms up to 193C the drum motor turns on and the code shows up every time. I can run the drum motor in service mode and it comes up OK.
  • 1,219 Answers
I have something simillar, but my solution was that I had toner on conectors above fixing unit
Posted on Jun 02, 2010
Canon ir3300 error code 000805-0002
canon ir2200 E000805-002
E805
The clock signal is absent for 5 sec or more after the fan drive signal has
been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The
DC controller PCB is faulty.
Action
1. Foreign matter
Is there foreign matter that prevents the rotation of the fan?
YES: Remove the foreign matter.
2. Wiring, Connector
Are the wiring and connector of the fan normal?
Developing fan (FM1): DC controller PCB (J302B)
Fixing fan (FM2): DC controller PCB (J308B)
Curl reducing fan (FM4): DC controller PCB (J311B)
Curl reducing fan (FM5): DC controller PCB (J311B)
Electrical unit fan (FM3): main controller PCB (J1028)
NO: Correct the wiring and the connection.
3. Fan, DC controller PCB
Try replacing the fan. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Nov 09, 2016 | Canon Ir 3300 Black & White Copier
How can i Solve the Error E100
Found from another site..
Check the following:
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB
Hope this helps!
Jun 24, 2014 | Canon Service Manual For Ir 600
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir 2220 ERROR CODE E261
U NEED TO INVESTIGATE
the input/output ports of the DC controller PCBs.
COPIER>I/O>DC-CON<DC-CON (5/7)>
P020 xxxxxxxxxxxxxxxx=runs from left to right 15>0
ADDRESS=P020
BIT-
0- zero-cross signal -
1- heater trigger 1 signal 0: ON
2- heater trigger 2 signal 0: ON
3- heater error OFF signal 0: error
4- not used
5- not used
6- M9 registration motor phase A pulse signal -
7- M9 registration motor phase B pulse signal -
E261 0000
The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected?
(zero-cross signal: J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
Jan 22, 2013 | Office Equipment & Supplies
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
How to clear an error fo canon copier ir 6800 cn with an e000061-0001
A E000061 is a drum potenal problem. It means the drum is not charged up correctly. It could be as simple as replacing the two post corona wires and cleaning the grid or making sure the primary charge unit is installed correctly. It may also, be a broking grid or corona wire > you may have to replaced the primary charge unit??? It could also be the drum potenal sensor or the DC controller or the drum..... I'd go for the simple stuff first and you can not clear the problem till the problem is fixed > Before I forget, you can also, turn the drum potenal off in service mode... It's just a band aid, it will not solve the problem..... Good Luck
May 05, 2012 | Canon Office Equipment & Supplies
E000007-0000 errorquick solution in IR 2200 Canon printer
Fixing film rotation error
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause: The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO: Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal: 5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440
msec OFF
NO: If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
Jan 27, 2011 | Canon (6981A002AA) for imagerunner 2200,...
E069 problem with my ir 105 tell me what to do?
these means that you have high voltage error, probably in high voltage pcb or somewheare in transfer assy.
These can occure if you mess around with bias settings or if you have fluctuation in your power supply network. The network should be checked first.
Here you go the things that can be faulty also:
- Check if the transfer charging assembly and separation
charging assembly are mounted properly.
- Check if the connector (T701, J723, J730) of the HVDC
PCB is mounted properly and also check the wiring.
- Replace the HV-DC PCB.
- Replace the pre-transfer charging assembly
Hope that helps!
Aug 19, 2010 | Canon Office Equipment & Supplies
Have an error code on Imagerunner 105 of E0005f2-001. Anyone know what it is and/or how to resolve. Thanks!
E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire E002 Fuser temperature not rising at correct pace, same possibilities as E000 E003 Fuser temperature drops. Same as E000 E004 Fuser problem: AC driver, SSR bad, wire shorted E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this E006 Fuser feed connector E010 Drive problem. Main motor, gears, etc E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller E030 Total counter E031 Option counter or total counter E050 Holding tray (duplex) home position sensor motor or board E051 Holding tray (duplex) home sensor motor or board E202 Panel locked up, but might be no Код ошибки, scan motor problem E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor E402 RDF belt motor or pulse sensor E403 RDF feed motor or pulse sensor E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motor E522 Sorter push bar motor
Jan 13, 2010 | Canon imageRUNNER 105 Copier
Error e012-0001 problem
It is a Drum Drive system over load/ or Drum Motor issue/ DC pcb issue. Need to check drum blades for all colors or if Dev. units are locked up.
Apr 03, 2009 | Canon CLC 1000 Color Copier
Canon imageRunner C3100N Copier Logo
98 people viewed this question
old marine
old marine
