Question about Cell Phones
Old door entry system in block of flats not even sure of the make. Buzzer works and resident can open door from phone. Visitor can hear resident at speach unit but resident cannot hear the visitor through the phone. How can I solve this problem?
  • 821 Answers
Hello,the only thing that would have happened to your old door entry system is the ear piece system that is faulty,this has to be fixed by the company you got the service from.it requires their expert fixing it so as not to get it compounded.i would have appreciated if you can provide the phones name.but the above suggestion is the reason why you don't hear your visitors through the phone.
thanks for using fixya,you are highly appreciated,
take care.
Posted on Apr 26, 2010
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
Have a clicker keyless entry with 4 diget code from old opener. klik2 and have new chamblerlin opener model 248735s want to program clicker to open garage door opener need instrustions i can print up
Often times, keypads and remotes are not compatible with newer models, even with the same manufacturer. If you are still interested in finding an instruction manual, try the Chamberlain website. You can also purchase a Universal Keypad, which will work with most models.
Mar 01, 2011 | Chamberlain Klik2u Universal Wireless...
Hi we have a gas dryer that does not run, heat
After 17 years this has done very well , check out the gas valve see if igniton jets are claen check flame senser you can do this from the back if belive , also check the vents are not blocked ,
But at 17 years is it worth spending money on ? hope this helps you
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
I have a motorola RAZR and the speaker doesn't work can it be changed?
Yes it can, but you'll need pricision tools to open it.
FYI: Speaker is used so that you can hear the other person from the other line talking.
Buzzer is used to hear your cellphone ringing, alert tones, alert tone messages, even making some music.
So in short Speaker is different from the buzzer.
Nov 01, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
My phone speakers do not work.
you can hear conversation and your friend can hear you = earpiece ok, microphone ok
phone not ring and not play music = buzzer broken or not connect to the main board.
check and replace if the buzzer is broken.
before you open the phone, please check the profile of your phone.
Sep 23, 2009 | RIM BlackBerry Pearl 8100
Lights on buzzer does not work
does your interior light and door light work when the door is open??.the lock mechanism has a micro switch that signifies when the door is open if this dont work niether will the buzzer...its a sound generated by the dash panel insert there is no sepperate buzzer.
Jan 22, 2009 | 2000 Volkswagen Beetle
Reprogram keyless entry system
1991-94 Nissan Maxima key less entry reprogramming procedure:
1. Enter the *original code found under the dashboard.
(*the code begins with the letter F and has 7 digits)
2. Close the doors and lock all of the doors,
enter the 7 digit code ( make sure you have your key in hand).
3. Once the code is entered correctly you will hear a long beep ♪ ♫.
While the beep ♪ ♫ is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps ♪ ♫)
Do not touch anything until the beeping ♪ ♫ stops.
4. To open the doors, the front windows and the trunk,
type: S(Clear) and the New 4 digit code and the door will open automatically.
5. IF by any chance you forget your new code. Just enter the original one and start all over.
Oct 23, 2008 | 1994 Nissan Maxima
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
