Question about Sony Televison & Video
I use Guideplus on my tv, everything ok with the exception of BBC1 channel which is one hour behind schedule. eg breakfast programme noted on screen as 0700 - 1015, whereas programme was actually broadcast 0600 -0915. This appears to be the same for all BBC 1 programmes throughout the day. This has been like this for one week now. I have reset the guide, but it remains the same. All other channels and timings are correct.
Did you find a fix? I have the same problem!
Posted on May 13, 2010
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
How can I get channels in sequence eg bbc1bbc2
Depending on your model, select channel 1 and tune for BBC1 and then 'store'. do the same for channel 2, tune for BBC2 and store again. Just repeat with each channel in turn
Jul 01, 2014 | Televison & Video
Bt com help btvision
contact bt vision its a free service you have to push some of the buttons in a particular sequence only they can tell you
Jan 14, 2014 | Computers & Internet
I have a Goodmans GTV26W3LCD TV. I have moved to another room on a similar aerial, but cannot get more than 2 out of the 5 basic channels.The channels give a good picture,I do not seem to be able to get...
The antenna has everything to due with reception.
Try moving it to a different direction or try a new antenna altogether. It's also possible that the three stations are weaker than the other two and the new room is blocking these signals more. It this case you would need to use an external antenna to retrieve the the signals.
Jun 16, 2017 | Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
I can record a show manualy while its on & all is fine. When I try to schedule a recrding it records but I get a blank screen upon playback. What am I doing wrong? I have directv.
Unless the tv and dvdr are paired I.E. both the same make and compatible models, then you will have problems. try setting the timer on the dvdr for a programme but set the channel to av(scart connecter used) and set the timer on the tv to the same.
Please note that AV2 on the tv usually sends the programme to the dvdr.
Mar 20, 2010 | Cyberhome DVR 1600 DVD Recorder
Cannot download TV Guide schedule-Verizon FIOS
With this problem I will suggest you to contact Verizon or motorola so they can help you better with this concern this is the number 1-877-466-8646....
Hope that helps.........
Sep 15, 2008 | Panasonic DMR-E85H DVD Recorder
Televison & Video Logo
2,951 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
