Question about Acer Aspire 3000 Notebook
Unable to get on internet wirelessly says no ip address
  • 137 Answers
Check your firewall settings, and take it somewhere to a public wireless connection to see if it picks up the signal. IF your running say XP, go to start; run; type in CMD and hit enter. At the prompt, type in the following..
ipconfig /release then hit enter.
they type in the following....
ipconfig /renew then hit enter.
Check it then by typing in the following
ipconfig /all
See if it picks up an IP.
Also make sure your wireless is turned on and set properly. Especially if its a DELL Laptop. There are numerous settings in the BIOS for them
Posted on Apr 26, 2010
Failure to connect to internet
hello there,i would like to try and help you. could you please provide me with the details you see under network information:
IP Address:
Subnet:
Gateway:
DNS1:
DNS2:
is your internet service subscription valid? what type of wireless router are you using?
Mar 18, 2013 | Acer Aspire One PC Notebook
My iPad computer iPhone all say connected to wireless but unable to browse internet
Is there any chance that in the last 24 hrs (or whenever your Internet stopped working) that you added a cable box converter to your home network by plugging a LAN/ethernet jack into the back of the box? If you did, that would be the problem.
On your PC, go to the bottom left corner and type "CMD" in the search/run box. This will open a pop-up DOS window. Type "IP config" and hit the enter key on your keyboard. This will tell you the IP address of your computer. You may have to scroll up to see it, but if you're running your computer through a router, the IP address should be something like 192.168.1.xx (the xx stands for a 2-3 digit number that is specific to each device on your network and can only appear once; 2 devices cannot have the same IP address).
If the IP address is something like 192.168.100.xx - then your problem is the router giving your computer an invalid IP address. My network router was doing this same thing and it frustrated the heck out of me. Long story short, much Internet research revealed the problem was because I had my cable box (the one that connect directly to your TV) plugged into my network. As soon as I unplugged it and rebooted my modem and my router, the problem was resolved.
I hope that helps.
Jan 29, 2013 | NetGear DG834G 54 Mbps Wireless ADSL...
When my wireless access point is turned on, my computer is unable to renew the ip address. I show excellend signal strength, but "little or no connectivity"
Hi, Your computer is most like have IP address permanently asign. To change the setting for windows 7, click start, click control panel, click network & internet, click network sharing, click connection, click lower left hand property, click Internet protocol version 4 (TCP?IPv4), click property and click obtain and IP address automatically. Your Router will asign IP address. Windows XP, Click start, click connect to, click to show all connection, right click to the wireless connection adapter, click the property and click the down arrow click to TCP/IP, click the property and change it to obtain IP address automatically. That should work for you. Get back to us if this information help you solve you solve the problem. Good day now.
Jul 13, 2011 | NetGear WG602 802.11g/b Wireless Access...
My computer is unable to get internet say wireless router unable
Hello there can you please tell me about the problem. Thank you
Jun 18, 2010 | Linksys Wireless-G Broadband Router
I am unable to connect to the internet using a wireless connection (signal strength good) When I use the repair wizzard I get a message telling me unable to renew IO address
If the Wi-Fi access point is a DHCP enable router, you should be able to browse the internet as DNS address will be automatically fixed in the Router firmware.
to check what IP address is assigned and more information on your wireless adapter
go to Command prompt by typing "cmd" in RUN.
type "ipconfig /all" without the quote.
you should be able to see IP address of your wireless network adapter plus default gateway and DNS address which are much needed in order to have internet access.
you can still assigned IP address etc manually.
Go to "Control panel"
Click on "Network and Sharing Center"
Click on "Change Adapter setting"
Now, right click on the wireless adapter and select "Properties"
Select "Internet Protocol version 4 (TCP/IPv4)" and "Properties"
In General tabs,select the radio button with " use the following IP address"
IP address : 192.168.1.x    (if the router IP address is 192.168.1.y)
                                        x=1 to 254, y=1 to 254 but x should not be                                           equal to y )
Subnet Mask : 255.255.255.0
Default gateway : 192.168.1.y ( IP address of the Wireless access point)
Preferred DNS address : Ask the Internet service provider
Alternate DNS address : Ask the Internet service provider
Click "OK" twice.
Your Internet should work now.
Jan 26, 2010 | Fujitsu Siemens LifeBook N3520 Notebook
Ping www.yahoo.com - FAILED
try to check the ip address before accessing the internet.
if you not getting a valid ip address then try to reset you d link router.
Apr 13, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Dec 21, 2008 | Linksys Computers & Internet
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless computer won't connect to internet
Somewhere in the network connections settings I recall seeing a checkbox to tell the laptop to automatically determine the IP address when connecting (as opposed to using the same one every time). Sorry I don't recall more specific directions ....
Jan 01, 2008 | Belkin (F5D7230-4) Router (587009)
Acer Aspire 3000 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
