Question about XFX NVIDIA GeForce 8500 Graphic Card
After reloading windows xp i am having scatered alphabets and digits on start up and also horizontal lines but if if i activate my motherboard vga windows loads perfectly using a seperate vga cable directly from the motherboard to the screen. Please help .I have an XFX GE 8600 GT FITTED ON A GIGABYTE MOTHERBOARD
Posted on May 27, 2010
If you see the startup XP logo with missed pixels or scatered, then probably the video card is not working properly. did you overclocked or something?
Posted on May 04, 2010
  • 63 Answers
Graplics drivers not installed properly....
Posted on Apr 26, 2010
Have installed windows 7 but having probs with VGA ... There is none ....
This motherboard has Intel graphics built in. I assume you were using a PCIE or PCI plug-in graphics card which is not working since you installed Windows 7. Swap your screen to the built-in VGA adapter on the motherboard and re-boot. Then download Windows 7 drivers for your video card. If this is not the problem, go to your BIOS settings (if you can) and reload default settings. If that doesn't work, plug a known good VGA card into an expansion slot and re-boot. Then proceed as above. Never add or remove cards while the computer is plugged in to power. Good luck!
Cheers, Don
Jul 07, 2014 | ASUS P5GV-MX Motherboard
Please tell me how to download VGA of Intel D845GVFN because when I setup window Xp service page 2 ready, my computer need VGA driver to stall so I have not VGA drive
You can download the motherboard drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Sep 09, 2010 | Intel D845GVFN Motherboard
Not supported for windows 7
if vga card not yet supported with windows 7. i suggest to re install back windows xp.
Jun 02, 2010 | Asrock 775i65GV Motherboard
Horizontal lines flickering
  1. Mybe VGA driver instalation not compatible with your monitor screen, you must check there are OR if you are use External VGA mybe theyare not compatible with your motherboard system
  2. if not work you must bring your monitor go to service hard,because your computer,because most likely your monitor easy damaged. good luck
Apr 25, 2010 | Microsoft Windows XP Home Edition
Out of range no display
Try pressing F8 when starting the PC, but BEFORE Windows starts loading. In the menu, select Safe Mode. Windows now startd with a very low resolution. You can right0click your desktop, select properties, then the Settings tab, and drag the reslution slider all the way to the left in Windows XP, or for Vista and 7, rightclick the desktop, sleect the lowest option, go to screen settings, and drag the slider all the way to the left.
After that, click OK, then restart your PC. Now you can try to increase the resolution step by step, and if it goes wrong start in safe mode and set it back a step. That way you will achieve the highest possible resolutioon (and better image quality)
I hope this helps,
Yannick.
Dec 07, 2009 | Princeton Digital VL173 Monitor
Drivers....I think
Hi David!
Follow this link bellow, download the modemdriver and tje vga driver, install them and you will be fine
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=42&DetailName=Driver&DetailDesc=P4S5MG/GL%20%20(V5.0)&CategoryID=1&MenuID=82&LanID=0
Btw, you will find all other avalible drivers for that mobo of yours. Download them all and store them on a disk just in case you need them again
Good luck David
Nic
Mar 01, 2009 | EliteGroup P4S5MG/GL+ Motherboard
No vga driver
i want to use windows vista. my CPU type like this. but it is not support the vga and sound. i don't have disc driver . where should i download it?
Dec 30, 2008 | Intel D865GBF Motherboard
Reloaded Windows XP PRO SP3 and I do not have all drivers needed.
VIA/S3G P4M890 VGA Driver V16.94.45.10 you can d-load all the drivers you need from the ecs website
Dec 22, 2008 | EliteGroup P4M890TM2 (V1.0B) Motherboard
XFX NVIDIA GeForce 8500 Graphic Card Logo
172 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
