Question about Ricoh Aficio 1013F Copier
I have a Nashua Aficio 1013, it gives me a SC549 error report and it doesn't perform any of its fuctions. how can i solve this problem?
  • 32 Answers
This is a fusing temp problem. Try the following to reset. function clear(yellow button) 107 hold down Clear button(red button)Machine will enter SP mode. Go to menu 7 (Data log) go to 807 ( SC/jam reset). Input 1 for yes. hold down the original type button (the button where you select Foto/text) then press #. Machine will reset and show action complete. Turn machine off and back on. If the problem is still there you will have to check the thermoster and might have to be replaced. But normaly this will do the trick.
Posted on Jun 08, 2010
That "reset" procedure is only to reset the SC/Jam log - not the error itself. This will solve nothing
Posted on Nov 22, 2011
Error sc549
fuser encoder error
-replace Encoder Ferrite core switch - B2234240
-replace Photo interuppter - Horizontal 7mm AW020190
Feb 26, 2014 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
Am having ricoh 1013 photocopier, and its giving an error message that "functional error,switch off mainpower and on"!
Low fusing temperature. Either the thermistor is bad or power supply board (unlikely). Service code can only be reset in service mode by a technician after problem is fixed
Mar 24, 2009 | Ricoh Aficio 1013F Copier
Service code 591
toner supply motor lock. The toner recycle coil in the back of copier is clogged up.Major pain to fix but can be done
Apr 26, 2008 | Ricoh Aficio 1013 Copier
831 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
