Question about Refrigerators
My Frigidaire side by side refrigerator's (GHSC39ETH) water dispenser light stays on when not in use.
  • PPGolfer Mar 24, 2008
    Thank you for your help. That solved my problem.
  • martygei Sep 19, 2008
    The dispenser light turns on and the ice cube selector defaults to both lights on whenever I open the freezer door. In other words, I open and close the freezer door which switches on the dispenser light. The ice cube selector (either crushed or cubed) lights up both. Then I have to switch the light off and select cubed again. The whole thing is forgotten once I open the door. It's annoying so I took out the bulb. This used to not happen when it was new, only after a year or two. It started to happen on occasion when the door was opened then closed, and now does it all the time.
    President:
  • Refrigerators Master
  • 2,651 Answers
Please forgive the question but, did you try pressing the light button on the dispenser itself???this light does act as a constant night light, or is activated when the dispenser paddles are switched.
Posted on Mar 24, 2008
Hooked my new Frigidaire gallery edition refrigerator water then power. Let it run for about twenty minutes! Tried to purge water, display went black dispenser light stayed on.
Dispensers are not made to stay on that long. (2 minutes) You may have burned out the dispenser coil but it should not be related to the display going blank unless of course the twenty minutes also burned out the low voltage and the relay that controls the water valves that is on the control board.
APPLIANCE 911
Dec 10, 2015 | Frigidaire Refrigerators
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Oct 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water dispenser lever on door broken off.
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help http://www.retrevo.com/samples/Frigidaire-manuals.html#Refrigerator
https://www.appliancezone.com/
Oct 15, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water Dispenser for Frigidaire
try mashing the wire end connector gently with a pair of pliers to tightn the connectorer and let me know if it stayes on
Jan 15, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
225 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
