Question about Panasonic Lumix DMC-TZ3 Digital Camera
Image totally blurred,
When turned on, the image seems totally blurred, like if it scrolled down. The colors are pink/purple dominant. The resultant photo is just that previewed in screen.
A few days before, it worked ok.
The camera hasn´t fallen nor over-pressed. It was just inside its bag in a drawer.
I've taken the battery off (hours) but stills going bad.
  • antmac Apr 29, 2010
    Panasonic hasn't a firmware update fot TZ3 (yes for TZ4). It has worked fine for years. If firmware didn't work it had failed before.
    Thanks for the idea.
    Guru:
  • 1,705 Answers
Could be a firmware issue, I suggest you go to the Panasonic website, follow links for support and/or downloads and see if there's a firmware upgrade for your camera.
Failing that, get onto the panasonic tech staff, they may be able to guide you further.
Posted on Apr 26, 2010
Image Color problem
Yes. and look at the color wheel for a residue build up too. Use alcohol to clean it with a cloth that will not leave lint behind.
Jan 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
When taking pictures there is a color displacement of some sort. Leaves like bright purples and pinks shadowing images.It is worse in lighted areas, the more sunlight/bulb light the worse the coloring...
The term for an out-of-focus purple "ghost" image on a photograph is "Purple Fringing."
This is fairly common in Digital Photography.
In order to minimize instances of purple fringing you may incorporate the following:
Avoid shooting with big aperture (Small /f number) in high contrast compositions.
Avoid overexposing highlights (e.g. bright sky behind dark objects).
Shoot with a UV/Skylight Filter or a Circular Polarizing Filter. These protect the lens and also help to Get bluer skies and cut glare off reflective objects.
You could also use Post-processing to remove purple fringing by scaling the fringed color channel. This can be done in an image editor like Photoshop.
These suggestions will help in minimizing the instances of color displacement for you.
I will look forward to your feedback and positive rating.
Sep 11, 2010 | Sony Mavica MVC-CD500 Digital Camera
Have a dark purple-like blurred image so my camera is useless
The CCD has to be changed. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in Sony service center.
Tom
Jul 17, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
How to get glowing effect in coreldraw
To create a glow: make a copy of your image you want to glow. paste to the side or original. select original. Convert to Bitmap, then use Gaussian blur, select pixel width of blur, preview it, then apply it when it look good. Put your copied image on top of the blurred image, bringing the copied image TO FRONT. voila NOTE change color of image to be bit-mapped BEFORE you convert to bitmap for a COLORED Glow
Dec 19, 2008 | Computers & Internet
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
Blurred purple image
The doe problem go away if you bang on the side of the camera? there is a known issue with the CCD sensor on certin model cameras that after a few years the glue or somthing dries up inside the sensor and it developes a bad connection. Canon has admit they know about this problem and they will fix them free of charge and pay shipping both ways. Sometimes users can bang on the side of the camera and the camera will work properly again but not for very long. I cant see your display so im not sure if thats it or not but the problem has this purple blackish symptom. Go to the canon usa webpage and then search around for your camera model and if there is a known issue it will say on their site. Then there are ways to contact them on their site.
Nov 14, 2005 | Canon PowerShot S1 IS Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
1,193 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
