Question about Westinghouse Washing Machines
I have a error code of E50 coming up on my machine and it will not do anything.
    Brigadier General:
  • 3,917 Answers
Error E50 is common on all washing machines and nothing specific to your machine. This is control modula fault. To rectify this you will need to replace the module. http://www.espares.co.uk/part/p/0/0/0/0/566534/pcb-configured-ewm2000evo.html?k=zanussi+zwf1631w
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 26, 2010
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
Jun 17, 2011 | Electrolux Washing Machines
Electrolux EWF1090 front laod washer not starting cycle? Error E50 is dusplayed on panel, however product manual has no reference to error E50? - NEED HELP
e50 is a motor error code,, this could be the motor itself of the wiring harness or the main computer board
Jan 26, 2011 | Washing Machines
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Dec 13, 2010 | Electrolux EW1000i Front Load Washer
ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
Error message "remote dvd 3"
PRESS 3 AND ENTER ON YOUR REMOTE OR VICE VERSA
Aug 03, 2009 | Panasonic DMR-E50 DVD Recorder
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Feb 16, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
