Question about Teac PD-H300 CD Player
When I press the button to open the cd drawer, the drawer doesn't open - any suggestions??
Just solved mine, turn the unit over and give it a shake and knock the underside a few times. I know you shouldn't be treating a delicate piece of hi-fi like this, but the tray comes out of the guide so you're just shakin it back in.
Posted on Feb 18, 2011
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
May 31, 2012 | Samsung Computers & Internet
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
My cd drawer will not open. It was suggested that a belt was slipping and I take it apart. How do I do this?
To be honest with you...this unit is quite complicated to be user serviceable.When to press the open button for the cd drawer..do you hear the motor running.this unit uses gears to open the drawer.If you can hear the motor..and even if not...the drawer is not opening...please get it serviced by a qualified technician.If you try to repair this yourself..you can easily cause more damage to the unit.....by all means...DO NOT DISASSEMBLE THIS UNIT YOURSELF.I hope this was helpful....
Oct 29, 2010 | JVC MX-K30 CD Shelf System
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD drawer won't open
hi, try opening up the cover lid, and manually give a mild push to the tray, must be some small jam, or the eject belt or gear,.let me know
Dec 28, 2007 | Teac GF-300 CD Shelf System
Teac PD-H300 CD Player Logo
513 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
