Question about Sony CMT-HP7 CD Shelf System
CD unit Dear Dan, thank you for your reply, we have managed to get the CD unit out. It appears that what we think is the 'reading head', (underneath the CD unit on a 'hinge' with a circuit board and a laser on it), has a large plastic pin on it which is sitting on a circluar disc/gear above it, (which itself has two pins), and thusly when the circular disc/gear is turning, the pin get caught on the pin on the 'reading head'. If we pull the 'reading head' away from the unit there is no grinding noise. It appears to be out of place as if the pin should be on the inside of the circular disc/gear instead of on the outside, (closer to us than the internal unit). I know this is long winded so sorry for that. Many thanks Kasey
  • 4,234 Answers
Effectively, the loading me4chanism is out of timing. This unit needs to be rebuilt. Why it became out of time is not important or knowable really. This is not a repair I would attempt without the service manual as these units have a specific re-assembly sequence. That sequence insures that the gear timing is correct.
Good luck.
Dan
Posted on Mar 24, 2008
Error message appears cd won't play
I don't have much to go on here. Can you post the actual message that shows up? Usually on these units, either the mechanism gets out of time or it gets jammed. The actuall message will help to determine which.
Thanks,
Dan
Mar 11, 2011 | Technics SL-MC70 60-Disc CD Changer
My DVR RW is not unable to read any DVD or CD. It cant read CD even while booting via bootable disc. The imae icon appears in the Explorer, but it cant read the discs.
the fault is from the lens (laser) of your drive, that's why its not reading discs. The lens is weak such that it cannot load discs.
How long have you been using this drive? I think its high time you got another one.
Good luck.
May 19, 2010 | Computers & Internet
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
RCA TV Model F36650 Verticle Issue
I think I have replied to the original posting. If not, please update this and I'll get the notification. With the site changes, it has become a bit more difficult to track continuing dialogues.
Thanks,
Dan
Dec 02, 2008 | Televison & Video
Rockford and fostgate
i dont think different brands ar compatible as such.
Dec 01, 2008 | Rockford Fosgate RFX-8030 CD Changer
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
Clarion DXZ775USB CD Player
Call your store manager directly for any information you need. Just ask for the store manager. If he or she cannot help then call 1-800-WALMART and ask that your concern be forwarded to the District Manager and you expect a call back. My store manager tells me they will stand for you with the warranty people.
May 09, 2008 | Clarion DXZ775USB CD Player
Cannot open DVD disc
Brain,
Is your drive supports DVD? Try to put a CD disc and see its reading or not. If this problem occurs for both CD's and DVD's discs then you might have problem in your drive lense. and if it only reads CD then your drive might not be supported for DVD's.
try to clean your drive lense using CD head cleaner, it might solve your problem, other than you have to replace your drive.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire 5580 Notebook
Rca rs2656 5 disc unit
Those "cleaning" discs are rarely effective. Open up the unit cna carefully clean the lens using a cotton swab and alcohol. Update this if that failes to resolve the problem.
Dan
Mar 26, 2008 | RCA RS2656 Shelf System
Sony CMT-HP7 CD Shelf System Logo
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
