Question about Alpine CHAS-634 6-Disc CD Changer
Error 1 wont play cds
Its in the trunk of my car and i washed thecar the other day so i think some water may got in the truck and wet the changer
  • 175 Answers
Leave it turned of for a couple of days maybe hit it with a hair drier carefully not to go to close to the lens,see how you go if it still doesnt work coald be a lens error
Posted on Apr 27, 2010
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Holes in the trunk?
These plugs are for draining water from the wheel well. There may be a leak behind the lights leave one of the plugs out for a day or too and see how it goes
Nov 30, 2017 | 2003 Toyota Celica
I have a brand new 2011 Nissan Sentra 2.0S. Found water in the wheel well of spare tire in trunk. Nissan tested it for leak and of course found nothing. Happened on 2 ocassions. Suspect undercarriage car...
probablly the result of insufficiently sealed body seams.empty trunk,sprinkle baby powder everywhere use vehicle or get it washed and look for trails in powder ...follow back to source.a little messy but very definitive!
Jan 20, 2011 | 2010 Nissan Sentra
My poor car has been having a few symptoms lately. For some reason, my trunk is soaking wet, and also the passenger side floors (both front and back) though not as wet as the trunk. My AC has not been...
Easiest way to figure it out, toss a friend in the trunk with a flashlight and grab a hose.
Pour all around the seal with the trunk closed, wouldn't surprise me if it's worn or falling off considering you're having trouble closing the trunk as well.
Do the same for all the doors, sunroof if you have and windshield .
Those seals normally aren't hard to replace and an easy way to make sure the new ones don't leak is to grease them before winters, some white grease works well, not the prettiest thing but it keeps the rubber from freezing and cracking.
Feb 07, 2010 | 2000 Mazda 626
Water is getting into spare tire area on 2006 Nissan Sentra
CHECK TO MAKE SURE THE WEATHER SEAL AROUND THE TRUNK LID IS NOT DAMAGED.IF YOU CAN GET SOMEONE IN THE TRUNK WITH A FLASHLIGHT TO SEE IF WATER IS COMING IN AROUND THE SEAL WHILE YOU USE A HOSE TO SOAK THE TRUNK LID GAPS
Aug 06, 2009 | Nissan Sentra Cars & Trucks
Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
Jul 27, 2009 | 2005 Toyota Corolla
I have a 2003 m3 convertible and the trunk fills up with water
I'm assuming you checked the seal around the trunk just to make sure it wasn't bumped off track in any way maybe taking groceries out or putting anything in? The car is too new to be suffering from any dry rot I should think. If you drain the water and it comes back I would think the seal around the trunk would be suspect in the matter.
Jan 14, 2009 | 2003 BMW 325
Floor wet in my mondeo
1 - After wash your car verify if the doors are wet inside. If so you have to change the rubber.
2 - stretch news paper in the trunk and after wash verify if they are dry. If not, you have to change trunk door rubber.
Jan 02, 2009 | 2001 Volkswagen Golf
Wet rear floor
I had a similar issue and found that the two rear drain holes for the sun roof came off and any water was running down into the trunk and also the rear floor was always wet. I pulled the rear of the roof panel down to expose the rubber tubes, re-seated them with glue so they would not come off again.
Nov 21, 2008 | 1994 Buick Park Avenue
Alpine CHAS-634 6-Disc CD Changer Logo
125 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
