I need help with my TV
I cannot see anything on screen cannot hear sound nothing works just when turn ON for 2 sec. line middle of the screen and after this is death.
Please help me
  • 129 Answers
Good day.
There is a problem with the vertical circuitry. It may be not be receiving supply from the flyback or the vertical IC is busted. Have it cheched by a repaireman.
Response is highly appreciated.
chris
Posted on Mar 24, 2008
SOURCE:
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
My TV is death
hi
open your tv clear dust , check capesitor,power supply ,transi sotr ,regester,
Mar 24, 2008 | Samsung SlimFit TX-S3082WH 30" TV
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc...
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
Mar 13, 2011 | Panasonic TH32LRU20 32 in LCD TV
White line through the middle of the screen
If it is just a vertical fold over then resolder its pin, if not work then you have to replace the vertical IC. Usually you can still hear sounds from the channel program it is tune. This applies to a crt type tv.
If you are not inclined in electronics.Its better to have it check by the expert. Live nasty voltages inside.
May 30, 2009 | Televison & Video
42 lg lcd no sound but picture on for about 2 sec and then still?
I would call LG and have them assist you with a repair. The most helpful number is 877-543-8325. It doesn't matter if you are in or out of warranty.
Dec 09, 2008 | LG 42LC2D 42 in. LCD HDTV
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Old Projection telvision on the fritz
you need to change the CONVERGENCE ICs , if you cant do it then it needs to be serviced by a HITACHI authorize service shop , hope this helps AJ
May 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Samsung model#TX83082WH
you have a weak power supply its simply trying to go out on you
Mar 14, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Ekse
