Question about Denon AVR-1601 Receiver
Small transformer is busted.part no. 2336073000.Denon AVR 85
Small transformer is busted.part no. 2336073000. what is the output voltage og this transformer
  • nottoobitter
    nottoobitter Jan 30, 2014
    This is a step down. From 120 to 100 is what they use it for in the denon so they can use all 100v transformers in every model reguardless to where they sell it. its a 9:8 ratio
  • nottoobitter
    they can be had new at MCMelectronics.com
5 Suggested Answers
SOURCE: denon avr 3000
Anyone want to buy a working Denon AVR-300?
hdurity@comcast.net
Posted on Feb 02, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
  • 8 Answers
SOURCE: I just need to find a schematic for a Denon
Does this help?
http://www.usa.denon.com/avr3300_technotes.pdf
Posted on Dec 04, 2009
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
Main transformer voltage
Google the complete model number of your "amplituner" and see if a schematic is available from the parts suppliers or if a complete schematic is available from Denon..
Dec 26, 2012 | Denon AVR-1604 Receiver
I have a Denon AVR 1509 and when I turn the power on it flashed green but after about 2 seconds it cuts out and and then flashed red every 0.5 seconds.
Usually its the power output stage . You can visibly check it if theres a burned resistor on the output amplifier. On the base of the Power output transistor if the voltage is the same as the collector pin it will indicate a shorted power amplifier circuit.
May 20, 2010 | Denon AVR-1508 Receiver
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
Hi, I'd like to use my Denon at overseas where
There should be a switch that you could set to the various voltages. Normally a round switch in one of the corners on the rear panel that you can turn with a flat screwdriver
Aug 02, 2009 | Denon AVR-687
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
Denon AVR-1600 Power supply problem (115V)
I have schematic in PDF file I convert to JPG still over 150KB I can not see properly with JPG format I do not know how to post it to you
Any way check in STBY PCB you must have 5.6V STBY that voltage supply to CPU or system control when you turn on the relay will switch AC line to the big transformer now if any thing wrong with the regulator or output or output drive it will shutdown automatic and the red LED will blinking indicated some thing wrong
Give me exactly location of the component in STBY PCB the small transformer TR?? C?? or R?? with voltage? connector number such as J ??
The service manual is about 20MB
Cheers
Dec 04, 2008 | Denon AVR-1603 Receiver
Denon AVR 3802
Hi there
You can easily obtain a suitable transformer here.....
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=19413&doy=9m2
Hope this helps.....
Feb 09, 2008 | Denon AVR-2802
Denon AVR-1601 Receiver Logo
154 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
