Question about Westinghouse Dishwashers
Westinghouse 921 freestyle detergent door
I have a Westinghouse 921 freestyle dishwasher which was in the house when I moved in (so no manual)
I run the cycle through and it seems to work but the detergent door does not open during the cycle so the tablet is still in there at the end (and the dishes dirty)
What opens the door? Is there something that I can adjust to get the detergent despensing door to open?
Thanks veyr much for any help
  • 6 Answers
SOURCE: dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Posted on Mar 07, 2008
SOURCE: My dishes comes out still dirty
I put a bottle of CLR in the dishwasher and I did a wash without any dishes. Repeat if needed.
Posted on Aug 19, 2008
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
SOURCE: my Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Posted on Mar 07, 2010
Westinghouse SB921WG dishwasher leaking even when not in use.
I would start by checking the hoses to the machine as well as the fitting connections.
Aug 27, 2015 | Westinghouse Dishwashers
Door seals rotting out on westinghouse freestyle 920 dishwasher
If the machine is kept idle for long time without use, these types of problem happens.
When not in use, apply talcum powder over the gasket. Moist the powder and apply as it will fall off . Leave the door slightly open by keeping some folded cloth or some other soft material and close the door.
Contact the service provider and protect the electronics by a water-resistant cover.
May 26, 2010 | Kenmore 15129 Built-in Dishwasher
Water not drainiNg after completion of cycle
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. This should solve the draining issue.
As for the dishes not being cleaned on the top drawer check the holes on the top spray arm. If the holes are blocked up with food you will get poor wash results. Best way to clean the spray arm is to remove it by unscrewing it and giving it a good clean under the tap and poking the holes to clear any blockages.
Hope this helps
May 02, 2010 | Westinghouse 24 in. MDP531 RF...
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Our westinghouse 921 does the first part of a cycle then switches off
most likely if your dishwasher fills and then stops with clean water still inside and hasent drained your problem is most likely your pressure switch is sensing an over fill situation possibly a blockage in the pressure switch hose or split in pressure switch hose or a faulty pressure switch.
Mar 29, 2009 | Westinghouse Dishwashers
Soap dispenser will not open in cycle
Hi Dookie1984
I'm Harvey the Master Plumber.
Your question is about: The small door that houses the dishwashing detergent (grain or gel) will not open during the dishwashing cycle. The detergent gets caked in that housing. This has happened about 10 times now in a row.
If it is still under warrenty it's time to make the call. If not then it may be time to consider whether it's more cost effective to repair or replace. Unfortunatly you won't be able to fix this and sometimes even the repairman can't. You can always utilize our Repair Directory if you decide to go in that direction.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Kenmore 15129 Built-in Dishwasher
Westinghouse freestyle 920
was there damage to the door,when the door closes is it closing freely or is it hitting the cabinet on both sides it may need to be pulled out about 1/2 "
Dec 29, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
66 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
