Question about Acer Aspire 4720 Notebook
Just installed Win 7 drivers on my acer 4720G. Everything's fine until recently my screen shows vertical and horizontal lines after passing the Windows 7's logo during start up. Re install the os but without nvidia driver and ok. Is it driver's problem or hardware?
    President:
  • 2,678 Answers
That would indeed appear to be a driver problem. Check with Nvidia for win 7 drivers for your graphics
Posted on Apr 26, 2010
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
I recently installed windows 7 as replacement to my windows xp OS, after installation my web cam cease to function. i tried for the driver but couldn't find one. pls. help. thanx
your camra installed but win 7 will not showing check from device manager if device manager show the image device then installed. this will work on when you r using camra for chatting
Mar 16, 2011 | Computers & Internet
Vertical lines on startup. code 43 Adapter display. 8800GTS win 7
check to see your direct x status by typung dxdiag in run and test if they all pass then I would check the card wattage rating and you max power supply load the card may be to much for your power supply
Feb 02, 2010 | Leadtek GeForce® 8800 GTS, (320 MB) PCI...
Acer lcd tv screen goes fluro green, only on some pixels not entire picture but rest of screen is not a very clear picture.
my acer lcd 32" tv just recently went of the blink. It has vertical, horizontal lines and fluro green screen. please need some advice...
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Display Screen
she might have changed the display settings, right click on your desktop and go to properties, go to the settings tab and change the screen resolution there. might not be the problem but worth a look, i had something simular when my daughter messed with my pc.
Jun 25, 2008 | Acer TravelMate 4010 Notebook
Acer Aspire 4720 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
