Question about Panasonic DMR-E30 DVD Recorder
Where to buy: RAM/DIGITAL PCB MODULE for PANASONIC DVD/VHS RECORDER DMR ES35V part # RFKNES35VGN
Slinteriors
  • 8617 Answers
SOURCE: panasonic dmr-es35v dvd recorder
It can be repaired however I am not sure if the hard drive is available for that unit or not. I would contact panasonic to inquire as to the availability of a new drive.Sorry I couldnt help you more with it.
Posted on Apr 06, 2008
SOURCE: Panasonic DMR-EH58- is recording only in B&W
The camera system was bought in USA. Changed output (in system settings) in DVD player to NTSC. Works fine now.
Posted on Apr 18, 2009
Bati99
  • 88 Answers
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Posted on Apr 19, 2009
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
  • 909 Answers
SOURCE: I have a Panasonic DVD Recorder DMR-ES30VEB could
Yes, connect to AV2 and you can select the output for AV2 from the menu.
Most tv's send a selectable signal out through av2 but if you match to your Panasonic, you may find it will automatically set up with the dvd recorder(like Sony Smartlink)
You simply go into the menu, select the av2 output set up and pick what you want to record. I.E. dvt, av1 etc.
Posted on Sep 04, 2009
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Panasonic DVD-RAM "Invalid Disc"
This would suggest the disc is defective, especially when all others work. I would return the other.
Mar 12, 2012 | Panasonic DMR-ES35VS
My Panasonic dmr-es35v has decided to cease recording, and makes loud grinding noises, any ideas, reset?
You can try a reset, but I doubt it would do much good. The loud grinding noises and failure to record sound to me like the DVD-RAM drive has had it. This sadly is not a cheap part to replace, and there's the issue of fitting/alignment/firmware upgrade etc.
Uneconomical for a model that is over 4 years old (since it has no digital tuner).
However, if you are prepared to spend a small fortune on a workshop repair/replacement DVD drive, go ahead, but I warn you it could cost as much as, if not more than the price of a new VHS/DVD recorder combo unit.
Feb 10, 2011 | Panasonic DMR-ES35VS
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need help with hook up
the exact diagram can be downloaded free at...
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
If I helped you, please take a moment to rate (help) me! Thank You for using FixYa!
Apr 06, 2009 | Panasonic DMR-ES35VS
Panasonic DMR-EH55 Ram Drive Failure
Buy a used DMR-ES15, DMR-ES25, DMR-ES45, or DMR-ES46 with a good DVD drive and swap out your bad drive.
Jan 23, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Error code U61 on a panasonic DMR-ES35v
component failure, the DVD Disk Drive Control Board
(Part No. VEP79132).
Panasonic will not sell this individual part but packages it a module, called the RAM/Digital PCB Module
(Part No. RFKNES15P).
Aug 20, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Panasonic dmr-es35v dvd recorder
Apr 06, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-E30 DVD Recorder Logo
167 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
