Question about Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven
My Smeg SA130P oven won't unlock after a self-cleaning cycle
The first time I used the pyrolitic cycle, the glass exploded inside. A technician fixed the glass, tested it, and said it was working.
The second time, the door won't unlock. Read some advice which said to switch off the power, but this has had no effect either.
I have only used the feature twice, about a year apart. Thanks in advance.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a Smeg SA130P
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Dec 14, 2010
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
    in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
    the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
    Sep 28, 2015 | Smeg Ovens
    H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
    Hello.
    Please apply the solution this way!
    To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
    • Program the oven to self-clean.
    • Wait 20 seconds.
    • Cancel self-clean.
    • Wait 20 seconds.
    To self-clean your wall oven, follow these simple steps:
    • Remove the oven racks.
    • Set your oven control to "Clean."
    • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
    • Select "Start." (To set a delayed start, see your Use & Care Guide.)
    Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
    Thanks for using fixya.
    Sep 07, 2011 | Dacor Ovens
    I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
    heatman101
    Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
    Fault 23 is displayed on the control panel after using teh self clean function on our miele double OVEN H398 BP2. IT IS NOT LISTED ON THE MANUAL WAHT DOES IT MEAN?
    F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
    Dec 12, 2009 | Miele DG 4080 Stainless Steel Electric...
    I have a smeg self cleaning oven on the first occasion I used it when it was just out of warranty to glass shattered and I had to pay eighty euros for a replacement. Last Tuesday I used the self cleaning...
    do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
    Sep 23, 2009 | Smeg DO81CSS Electric Double Oven
    We have a SMEG self cleaning oven however the glass door is filthy and we are seeking the best approach to clean it without damaging
    Purchase 3M stainless cleaner for the stainless parts, do not use spray and wipe or similar as it removes the marking or etching indicators (temp. etc)
    You can use oven cleaner on the glass, but try not to let it go on the stainless parts yet again.
    Hope this helps?
    Jun 21, 2009 | Smeg DO81CSS Electric Double Oven
    Cleaning better than self-cleaning
    What you have read is correct, the catalytic lining can be damaged by corrosive sprays. It should be safe to use 'Easy Off ' on glass though.
    The standard Auto clean cycle is the best method of cleaning that i know of.
    Nov 29, 2008 | GE JTP86 Electric Double Oven
    Smeg oven cleaing cycle
    Typically on any self cleaning oven, remove the racks and any pots/pans etc and wipe any excessive food stuffs etc from the bottom and set it for 3 hours.
    Sep 17, 2007 | Smeg S1100MFX5 Electric Single Oven
    Open Questions:
    See all Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Questions
    Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven Logo
    775 people viewed this question
    Top Smeg Ovens Experts
    ashburton
    Hjalmer Lamminen
    Hjalmer Lamminen
    Jason Harris
    Jason Harris
    Are you a Smeg Oven Expert? Answer questions, earn points and help others
