Question about Kenmore 22442 Top Load Washer
Water will pour into the machine but the drum wont spin or drain.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Washer wont drain replaced pump but still wont drain
Pour drain cleaner solvent in the drum and in about 10 minutes, after boiling a large pot of water, pour the hot water in the drum. Let it sit for a while and repeat if needed. Detergent and softener will build up over the years.
May 06, 2012 | GE Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Drum wont turn water wont drain checked pump suspect frost indrain hose inside washer drain pipe seems crunchy
Your probably on the right track,if you can expose the drain pipe to heat to melt frozen portion would be an idea or you could pour hot water back the drain hose(at its outlet) to melt the water in front of it-thats the most obvious thing first anyway,small socks are a nuisance also getting clogged in drain at exit from drum to drain pump
Jan 08, 2010 | Indesit W 123 Front Load Washer
WATER LEAK
Probably slow to drain due to blockage or restriction, it is going into spin with more water in the drum than there should be.and the water is being thrown out due to centifrugal force.
If it has a filter, then check it and clean if required.
Nov 16, 2008 | Washing Machines
My whirlpool awz410 is not spinning
if its draining while its filling ,raise the drain hose higher than the water level and it wont syphon.
May 01, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Kenmore 22442 Top Load Washer Logo
132 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
