Question about Sharp MX-2700N Color Copier
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
  • 33 Answers
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Posted on Jul 20, 2010
I have Sharp copier AR-M236 with error code:f2-04, how can i remove this error?
The error code usually refers to a faulty toner cartridge. If turning the machine off & on doesn't reset the machine then you may have to replace the toner cartridge.
Hope this helps.
Dave.
Oct 09, 2017 | Sharp Office Equipment & Supplies
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
Sharp MX-2300N error DK - which drum part number?
It looks like they are the same regardless what color you need to replace. Just buy one and go with it. Here is an example from amazon: http://www.amazon.com/SHARP-MX-2300N-1-COLOR-DRUM-MX27NUSA/dp/B00AA961GI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1425339155&sr=1-2&keywords=sharp+mx2300n+drum
You can also contact a local specialized provider such as Cartridge World who can find exactly what you need for you.
Mar 02, 2015 | Sharp MX-2300N Color Copier
F2-40 ERROR
I am assuming your copier is a mono copier only & not full colour, if this is so then the error code refers to a toner supply fault. If you remove the toner cartridge & gently shake it side to side, turn the machine off & then on, refit the toner cartridge & check to see if the machine has reset. If the error is displayed again you may have to replace the toner cartridge with a new one. Again, powering the machine off & on should reset the error message.
Hope this helps.
Aug 13, 2014 | Sharp Office Equipment & Supplies
Getting maintenance code DK...What is it referring to?
DK refers to the counter for the black developer powder.... a service call will be needed for this
Feb 17, 2010 | Sharp MX-2300N Color Copier
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Dec 23, 2008 | Sharp MX-2300N Color Copier
Sharp error codes
I have a problem with error U2-40 in photocopier sharp AR ......
I need help
Nov 21, 2007 | Office Equipment & Supplies
Sharp MX-2700N Color Copier Logo
502 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
