Question about Amana ABB1927DE Bottom Freezer Refrigerator
Doesnt freeze,now fridge is getting hot i cleaned it out
Most likely you have a freon leak. If the motor is still running, the condenser coils should be warm. if they aren't, then they have no coolant left and will probably have to be replaced.
Posted on Apr 26, 2010
Freezer not freezing. meltdown?
clean the accumulated dust from under the fridge. The fridge doesnt get cold enough, the freezer gets too cold, it needs air to pass through, grab the dust, or vacuum so that air can pass across the coils
Jul 07, 2014 | GE Profile PSI23NCR Side by Side...
Refrigerator doesnt seem to cool enough, things are freezing in the bottom shelves of fridge but nothing else is getting very cold
Take a hammer and tap lightly on the coils every half inch. It will take a few minutes to do this to break up the crud in the coils. The crud may plug up a dryer, but it was not working anyway...
Apr 07, 2014 | LG LSC27921ST Stainless Steel Side by Side...
Hotpoint mistral plus
Sounds like a faulty thermostat, although fast freeze usually bypasses the stat so should then get to temperature. If the compressor and condenser are getting very hot and all is clean, check there isn't a condenser fan stuck underneath that is seized. If not, may have had a bit of a refrigerant leak and sucked a bit of air into the system. Call an engineer
May 19, 2012 | Washing Machines
Freezer keeps freezing up. But the fridge doesn't stay cool.
the reason the fridge doesnt stay cool is because the freezer keeps icing up, try defrosting the freezer and try cleaning the condensor coils and this may help.
Mar 15, 2011 | Refrigerators
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge has hot spot
Hit it with a big stick!
Mar 24, 2008 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
242 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
