Question about Hayward H Series Induced Draft Abg 100,000 Heater
Pool heater gas fire lights up and turns off 10 secs later
Gas lights and turns off 10 seconds then 30 seconds later it relights then goes off again continously; water is circulating heater fan is on gas on and electric on i tested temp control and that is working >
    Problem Solver:
  • 5 Answers
Assuming you don't hear any banging noises, that cycle is by design. There is a fault. 2 possible causes are the ignition board is bad, or the ignition sensor is not returning a voltage indicating the flame is lit. Take this out and put the ignition piece on your stove flame. Check for voltage while on flame (DC millivolt setting on multimeter). Put one probe on ground other on sensor lead. If it doesnt have voltage this is bad. If you do, its possible your board is bad.
Posted on May 24, 2010
Pilot wont light
Pilot won't light ...
If we are talking about an OLD TIME "open flame"
PILOT...
There is a lighting sequence... Push & hold the button
put a MATCH to the gas and count to 30 (thirty seconds)...
Will USUALLY get the job done...
The HOLDING for 30 seconds... ALLOWS
time for the THERMOCOUPLE to warm...
assuring the flame is active and RAW GAS is
not escaping (important safety feature)...
MOST common cure for FAILURE to stay lit: REPLACE
that THERMOCOUPLE...
Still carried by most hardware stores... it is important
not to OVER-TIGHTEN the new replacement...
Ideally... you should MEASURE THE LENGHT and
make sure you are buying the right length/size...
Amazon example
Honeywell CQ100A1013 24 Inch Replacement Thermocouple for Gas Furnaces...
eBay example
Universal Thermocouple 24 works with Most Gas Furnaces water heaters...
I buy two...
(I have a SPARE IGNITER or Thermocouple for
every oven, water-heater... heater and patio heater
that keeps my wife happy).
Carnac the Magnificent
Nov 18, 2017 | Heating & Cooling
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
How do i relight pilot light for hot water again
Me again. You could have replied to me as a COMMENT, then I get a notification. Somewhere at the front with easy access will be a red button, you hold it in for 10 seconds and then press the spark ignitor. IF it lights, you have to hold it for another 30 seconds or so to heat up a safety device called a thermocouple. Release the red button slowly and you should see the flame. If you don't see any flame, keep repeating the task until you do. You have to pull the gas all the way from the propane tank.
May 24, 2016 | Water Water Heaters
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
Hayward H Series Induced Draft Abg 100,000 Heater Logo
1,340 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
