Question about Sport & Outdoor - Others
I have a orbit max 2 gym put together today. but dont know how too tension pulleys.any dvds out there ..
talk2ginny
  • 34 Answers
SOURCE: i took the tension apart for a kenmore 148.15600 model
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Posted on Jan 31, 2009
  • 1986 Answers
SOURCE: Cannot find the tensioner pulley to put my alternator back on
The smooth rounded tensioner pulley has a 1/2 inch drive recessed ratchet drive fitting in the outer side of it. Reach down and feel it with your fingers and insert the ratchet drive into it. Look around the underside of the hood and engine bay for a small diagram showing the belt, pulleys and tensioner.
This pulley is either a slider or a spring loaded pulley. If it is a slider, there will be one or two bolts with "slide" areas that the bolt can move through, and possibly a third bolt that controls the tension. If it is a spring loader, there will be a pulley that looks like it is on a lever. There will be a "bolt" type head, a hole for a ratchet, or a square area on the end of the lever to twist it away from the belt. If it is one of these, the belt tensioner will move relatively easy.
Posted on Aug 18, 2009
joshnaz
  • 186 Answers
SOURCE: i dont know which pulley is the tension pulley and
Serp belt removal:
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: how to put together a weider pro 4100 gym?...
Go to iconservice.com click on manuals input manufacturer and model name.
WEIDER & 4100
Posted on May 23, 2010
SOURCE: Hi I just bought a used helix 9800 home gym and
I have one I can email or fax you tomorrow
Posted on May 31, 2010
I need information on how to set up the pulley system
Go to www.body-solid.co.uk then you will see support click on it and choose your PDF for your machine it will have the pulley diagram that you need it is the same product!!
Apr 07, 2010 | Body Solid Body-Solid EXM2500S Home Gym
Need help to put weight machine together
i need a diagram of a marcy by impex weight machine 150 lbs. i cant figure out how thw pulley system goes.
Aug 14, 2009 | Exercise & Fitness
POWER STEERING PUMP PULLEY PUTTING BACK TOGETHER
if u mean the fan belt ??,the power steering pump have tensioner undo the bolt and move to close to the belt if u wanna try on the belt on if dont ,try using the alternator tensioner after that tight it all up also make sure the belt is tighten up not slacken
May 18, 2009 | 1995 Dodge Spirit
I cant find the tension? I get it on the pulleys,
The tension release pulley, located just below and in front of alternator, has a 1-2 slot in the center of pulley. Insert the 1-2 inch breaker bar in middle of tension pulley and pull up, tension will be released. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 27, 2009 | 2003 Chevrolet Silverado 2500HD
Instructions
Just did mine today.....Jack up the front as high as possible, remove front passenger wheel, put jackstands under car so it doesn't come down on you, remove the plastic inside fender well by taking out the 2 bolts and 3 plastic toggles, you need to remove the alternator belt to get to the power steering belt so loosen the center nut on the idler pulley/tensioner and then loosen the idler using the bottom nut/bolt to take the tension off the belt, remove the alternator belt first drawing a picture of how the belt is routed on all the pulleys for reassembly. Now loosen the 2 face nuts/bolts on the power steering belt idler pulley/tensioner and then use the nut/bolt on it's bottom to take the tesion off the belt and then remove the belt. Reinstall the belt and reverse everything to get it back together. Put on a new alternator belt on while your at it.
Jul 22, 2008 | 2001 Mitsubishi Diamante
Sport & Outdoor - Others Logo
41 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
