Question about Panasonic PT-51HX41 51" Rear Projection Television
I have a panasonic tv that just started to give me a distorted picture i have tried the convergence and it will not move
  • 1 more comment
  • Quack1 Mar 25, 2008
    My picture bows in in the middle of the top and bottom of the screen. I recently had the blue convergence fixed, now this is a new problem.
  • Anonymous Apr 02, 2008
    i have a blue shadow on the images of the tv
  • cuddy81 Apr 05, 2008
    Yes, we have blue and yellow bowing up from the bottom. Have tried convergence. I am thinking it might be the projection bulb itself.
  • Panasonic Master
  • 5,138 Answers
REPLACE your STKs 2 of them STK392-110sor150,,,,,
Posted on Jun 13, 2008
SOURCE:
The picture of my tv is distorted and wavy. i can see that there is an image but can't make it out very well.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Toshiba 42H81 42" Rear Projection...
Blue and red wavey lines and distorted picture
May 20, 2010 | Toshiba 53H71 53 in. Rear Projection...
Picture is distorted and jumbled
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
May 12, 2010 | Hitachi 57F500 57" Rear Projection...
Distorted picture
  • Screen looks 3D
Feb 16, 2010 | Panasonic PT-53WX52 53" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
  • Screen looks 3D
Feb 08, 2010 | Hitachi 57F710 TV
Burning smell and distorted picture
  • Screen looks 3D
Sep 16, 2009 | Akai PT5492S 54" Rear Projection...
Top of picture has distorted curve
  • Screen looks 3D
Aug 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Distorted picture
  • Screen looks 3D
Feb 18, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Distorted Picture
  • Screen looks 3D
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Distorted picture
  • Screen looks 3D
Nov 17, 2007 | Toshiba 51H84 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
