Question about Sunbeam Transformer (ICTRBA) ATX Full Tower Case
How many parts in transformer & briefly explained
  • 476 Answers
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
Posted on Apr 26, 2010
Where can i find a transformer for a squier 15watt practice amp.
For Fender parts and schematics, call Fender Customer Service at 800-856-9801. I will mention that the cost of replacing a transformer in a 15 watt Squier amp would lead me to just replacing the amp
Feb 02, 2015 | Squier Music
Transformer broken 3 times!!! nothing strange, do not move or fell or connect to other things, use it only one time and burned !!!??
I assume you are using OFFICIAL Moog transformer. This takes a 12 VAC 500ma trnasformer which is VERY uncommon for pedals. DO NOT use the common transformers for most pedals which are around 9VDC as they MAY appear to work briefly but will not operate this unit. Let me know what Moog model power transformer you are using.
Jul 26, 2011 | Moog MP 201 CV/MIDI Control Multi Pedal
Drivers windows XP I have windows 7 > Windows
can you explain me the problem briefly so that i can help you
Feb 24, 2011 | Acer Computers & Internet
Dvd palyer cd drive open not close no romote & dvd munual & no cd play
hi,
can u explain the problem in briefly. the only u will get a better solution
ok
Jan 11, 2011 | LG RH177 DVD Recorder/HDD Recorder
My nokia Software not work correctly & very Problems.
briefly explain your problem..so that we can provide you correct solution.
Sep 04, 2010 | Nokia 3200
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
VMOC205SS quit heating, it runs but does not heat? What part do I need?
the heating components of a microwave r the diode, magnetron, and transformer. checking a unit plugged in can be dangerous seeing there is about 5000 volts from the step up transformer. if you have a amp probe you can check the amps at the wires powering the transformer. if you have less than 12 amps, and 110 volts at primary side of transformer change the magnetron and diode
May 18, 2009 | Viking VMOC205SS Microwave Oven
Problem when switching on Denon AVR 2803
The sound you describe is usually a mechanical noise from the transformer/case work. Home theater amps tend to have quite large transformer in what is, due mainly to its size, a rattly cabinet.
Over time, the lamination inside the transformer can loosen which could explain why it has only just started doing.
Alternatively, one assumes you moved the amp when connecting the new kit? This may have let the case work rest in a new way which is proving susceptible to relaying the vibration caused by the transformer as an audible noise on switch on.
Feb 15, 2009 | Denon AVR-2803 Receiver
What are parts of the map?
http://geography.about.com/od/studygeography/a/mapparts.htm
Jun 11, 2008 | Acer Aspire 5100 Notebook
Can anyone help to explain why?
The output section has a problem and the amp is in "protect" mode. This will most likely require the replacing of the output transistors and a few other parts. Figure about $20 in parts plus your local labor charge.
Dan
Mar 19, 2008 | Denon DHT500SD System
Open Questions:
See all Sunbeam Transformer (ICTRBA) ATX Full Tower Case Questions
Sunbeam Transformer (ICTRBA) ATX Full Tower Case Logo
162 people viewed this question
Top Sunbeam Computers & Internet Experts
David Payne
David Payne
Are you a Sunbeam Computer and Internet Expert? Answer questions, earn points and help others
