Question about Campbell Hausfeld 19.2V 2 - Speed Cordless Drill with Bonus 250 - Piece Accessory Kit - DG151905CK
What will happened if i did inserted the 120volts charger to 220 volts?it was supposedly done to 120volts..can i still use the charger nor can i fixed it?
If the charger is rated only for 120 volts and it doesn't work after plugging it into 220, it is probably toast. Anything can be fixed, but unless you are a expert, it is probably cheaper to buy a new charger.
Posted on Apr 27, 2010
Will American power tool batteries work after being plugged into a 220 charger
Yep. they will as long as the 220 volt charger was connected to 220. If a 220 volt charger is plugged into 110 volts it may not charge the battery but no damage to the battery will happen.
Dec 04, 2014 | Drills
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
How to repair if water can't insert
What do you mean "if water can't insert"? Do you mean that the machine is not filling up with water when it's suppose to?
Jul 08, 2014 | Panasonic NA-F65B2 6.5KG WASHINGMACHINE...
How can I change input voltage of charger from 120 volts to 220 volts?
http://ecx.images-amazon.com/images/I/21b-Ru01zNL._AA160_.jpg
There are a number of converters that convert 220v to 120 v and visa versa. If you do a web search " 220 to 120 converter, you'll get many sites.
Jun 01, 2014 | Bosch BC630 bc660 14.4v - 18v litheon...
I I have purchased PS3 160 Gb from US it reads 120 Volts.Can I use this in India on 220 volts with out converter from 220 to 120 volts
you cant use that sir... if you plug in your 120volts console on 220volts your console will surely explode.... you better use a converter for your console...
thank you sir rate me if you think i help you!!!!
Jul 28, 2011 | Video Game Consoles & Games
Have a two pole 80 amp push in breaker that is reading 220 on 1 load side and 120 on the other load side? how is this possible???
220 volts power to device. 120 volts is coil volts of the relay. when this 120 coil energized by control commanded, the 220 volts passes to device. When it de-energized, 220 cuts off to device.
How you are getting 120volts. It's from transformer 220-120 which will be in your unit.
Thanks.
Jan 10, 2011 | Heating & Cooling
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have the Makita DC18ra s charger for 110V. by mistake i insert it to 220and burn the fuse and a components as described on the borad VDR1 01 Do someone knew what is this components thank alon
yes you can fix it i have done 2 charges but white you are in there if you chance the large round capacitor to a 450v one you then can use the charger in 220 v you will have to increase the size of the voltage resistant diode to 240v (the vrd101 part in the charger) or by pass it with a straight bridge then the charger should work in 220v because the rest of the charger is exactly the same the parts will be around $10 ibought the parts from farnell
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Carrier air conditioner
Is this a window unit or split system? If window check wall plug for power or just plug in something that uses the same voltages..example 110-120volts plug in a lamp... if a 220-240-volt system , plug in .........???? or a volt meter to read your voltage s.?!.
Aug 25, 2008 | Carrier Heating & Cooling
Campbell Hausfeld 19.2V 2 - Speed Cordless Drill with Bonus 250 - Piece Accessory Kit - DG151905CK Logo
73 people viewed this question
Top Campbell Hausfeld Drills Experts
Gil Shultz
Tom Chichester
Dan Apthorp
Are you a Campbell Hausfeld Drill Expert? Answer questions, earn points and help others
