Question about Epson LQ-2180 Matrix Printer
How to delete print jobs from printer LQ-2180i
  • Epson Master
  • 12,061 Answers
Ok, Unplug printer from PC & Power. Also go into the PC, and right click, on printer icon, and select "Cancel" print job, or delete, whatever.
Posted on Apr 26, 2010
I cannot clear print jobs in memory of printer EPSON LQ 2180
You can try a simple Restart to see if it corrects the problem.
Jun 30, 2011 | Epson LQ-2180 Matrix Printer
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ570+ RUNNING ON WINDOW 7
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Sep 01, 2010 | Epson LQ 580 Matrix Printer
Wep lq dsi 5235 how to cancel print jobs immediately
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Epson Stylus Photo 1410 Printer
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
I have an LQ Epson printer which has refused to print it passes out the paper which is blank. when i command a job, it just prints a blank page with out any writings
Do you hear the sound of the solenoid of the printer head during printing? if not then there is a cut traces on the head cable. if you hear it then you have to change the ribbon. try also to check the lever adjust bar on the printer (usually found with a blue head on the left part if it is an lq-2180++ model or on the right part if it is an Lx300++)
Feb 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Jan 12, 2010 | Epson LQ 570+ Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Printer is a Canon MP470 all-in-one, USB connected. OS is Windows XP. Latest printer drivers are installed. After print job completes, status of print job remains in print spool as "printing". If I cancel...
Is your printer hooked up to your network?
Make sure all your settings are correct and try connecting the printer directly into your computer. Then print if it does not work still then comment back and I will be glad to help.
Hope this helped.
-Ryan
-Please rate if this helped
Feb 19, 2009 | Epson LQ-590 Matrix Printer
Speed of print
A printer is designed to print at a certain ppm (page per minute), so really there is only one way to speed it up. When you select the print option from the File menu, you can select properties and see if you can change the dpi (dots per inch) of the document. Your document will print faster but you will lose quality.
Nov 27, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Matrix Printer Logo
438 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
