Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
The bottom brush does not spin although you can still get suction from the hand held pipe
  • Dyson Master
  • 379 Answers
Posted on Apr 27, 2010
Dyson brush roller spins intermittently. it starts out good but then stops
Do you have a burning rubber smell at the same time? Turn the machine over and remove the bottom cover. Hook a loop of cord under the belt, pull it up wards and pull the brush out. Remove one end cap and pull the spindle out from the other end. Remove the fluff and hair that is tied around each end.
This shows quite well.
https://www.youtube.com/watch?feature=player_embedded&v=cYqOEpZgocg
Put the brush back and see if that fixes it. If not, then you need to change the two belts, and possibly the clutch. The same guy at Vacuum spot shows clutch servicing, but you may wish to get a professional to do it. How to check the Dyson DC04 Roller Brush Bearings
Mar 21, 2016 | Dyson Vacuums
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Oct 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Great hose suction, awful floor performance
Lose of suction usually means a clog either in the hose, dirt inlet by the brush roll and clogged filters. But a belt that has stretched to where it won't turn the brush roll under load will make it appear as no suction. If you have replaced the belt in a while, I would try that.
Apr 24, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Mar 25, 2008 | Vacuums
Eureka 4700a bagless vacuum
it's probably the lower tube that is plugged, disconnect the lower tube at the elbow, use a large pipe cleaner (bent at the end your pushing through, as to not puncture the tube itself.) it should emerge just behind the brush. check in and around the pipe cleaner for any debris.
Nov 18, 2007 | Eureka 4700A Maxima Bagless Upright Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
136 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
